Disco 3 Coolant loss from expansion tank when towing
Old Apr 17, 2023 | 07:36 PM
Amfin2's Avatar
Default Disco 3 Coolant loss from expansion tank when towing
Hello I hope someone might be able to help me. I have a 2007 Disco TD V6 that runs fine ordinarily but as soon as I hook up my caravan I get coolant loss from the expansion tank. I have done a pressure test and replaced the cap on the expansion tank. Coolant test for head gasket came up negative. No oil contamination and motor runs fine ordinarily. Symptoms only exist when the caravan is on. The car is approaching 240000KM. Does anyone have any ideas?
Old Apr 17, 2023 | 07:41 PM
loanrangie's Avatar
What country are you in, no TDV6 in North America so better off on a UK or Aus forum. Possible causes are egr cooler leaking,stuck thermostat, failing viscous fan clutch, blocked radiator, failing water pump just to name a few.
Old Apr 18, 2023 | 03:55 PM
DakotaTravler's Avatar
Coolant loss from expansion, as in boil over or do you mean the level in the tank goes down?
thorgal
Feb 17, 2023 02:02 PM
FlyingZebra34
Dec 24, 2020 10:58 PM
Wheelspin
Aug 12, 2020 12:02 PM
starcraft1
Aug 15, 2013 10:32 AM
