Driver’s door water collecting ? - NOT footwell -
Old Feb 20, 2024 | 10:11 AM
archaeology_student's Avatar
Received new belt moulding and was wondering if anyone had insight on how to remove the LR044650 piece?
I can not pry it off of the door 🤬🤬🤬🤬
Thanks in advance.
Originally Posted by archaeology_student
To re-iterate, filter is dry and checked out. Interior is dry on both sides.
You seem to be adamant.
I used grass trimmer twine/string and fed it down. There is no wetness inside on the carpets on the drivers side or passenger side. Drainage tubes are still in good order and connected at the bottom and not rotted through. It has sat through some serious rain since and it is not wet inside the cabin.
Appreciate your enthusiasm, but, @aljpro2000 has provided insight into why there is moisture in the door. Once I have replaced the part referred to I will report back.
hhalimi
Dec 13, 2025 08:13 PM
gulfcoastrover
Jan 27, 2022 03:11 AM
Externet
Jan 13, 2016 12:10 AM
jalodge
Dec 23, 2013 08:21 AM
llinneman
Aug 11, 2011 12:31 PM
