Fuel Rail Priming?
Old Jan 6, 2023 | 07:54 PM
DakotaTravler's Avatar
I wonder if the issue is the change in gasket designs.
Old Jan 6, 2023 | 07:58 PM
The gaskets with the "things" on then, "Fits LR3 4.4 V8 PETROL UP TO VIN 5A348162"
The ones with no bump things are for "LR3 / Discovery 3 V8 4.4L | 05 - 09 | From VIN 5A348163"
Old Jan 6, 2023 | 08:34 PM
droolyFace's Avatar
That’d be the issue. I’m pretty sure it’s and older VIN. I’ll put in the old ones and see what happens
Old Jan 6, 2023 | 09:10 PM
droolyFace's Avatar
Originally Posted by elemental_garage
What prompted you to do the intake in the first place? Is it possible you're chasing the original problem and the intake was not the fix?
For a vacuum leak a smoke tester can be great. You can also redneck it and use shots of starter fluid around the engine to see if you get an idle/starting behavior change, but it can be a little dangerous if you overdo it.
I smoked tested it and had leaks from each side on the bottom. When I pulled it, the lower gaskets were shot and leaking for sure. When things calm down (busy family stuff) I’ll post photos.
Old Jan 6, 2023 | 09:26 PM
I tend to not reuse old gaskets. You can get the sets with bumps for around $20 on PartsGeek, I think.
Old Jan 6, 2023 | 10:20 PM
droolyFace's Avatar
Normally I wouldn’t but I need to make sure it fires up first. And I’ve got to use it.
Although balancing that on the chance of something old and brittle breaking is a thing too.
Old Jan 6, 2023 | 11:26 PM
droolyFace's Avatar
It works!
Using the old upper manifold gaskets with the weird cube things worked.
It fired right up and spun like a top. Then I turned it off to report back here and get ready for bed.
THANK YOU for everyone’s input. I’ll do a better write up when I’m not half asleep.
New seal without cubes for VIN’s newer than mine apparently. Note the big gap below the seal (which is really the top)
Old Jan 7, 2023 | 01:58 AM
elemental_garage's Avatar
Glad you figured it out! Good info on the intake seals.
Old Jan 7, 2023 | 10:58 AM
droolyFace's Avatar
(also posted in my other, really long thread)
Alright, I got it working last night. As mentioned somewhere, I replaced the new upper manifold gaskets with the old ones I took out. The truck was hard reset and then I also reset the adaptation values.
Important note on the upper gaskets - they are VIN specific in that there is a cutoff as DakotaTraveler noted.
So I went for a nice drive this morning and it ran great. As I was joking with my wife last night, I told her the engine light would come back... and it did after an ignition cycle. So the light and same lean codes are back and I get to order the right gaskets and do this a 3rd time. I''ll do another smoke test and see what I see although that should be after all the new gaskets are in.
Here's a PDF log from this morning's drive. Where the levels top out in the 20's for long and short term it's when I was stopped at a light, or in park idling and watching.
This is very interesting and has motivated me further to track this down.
File Type: pdf
Old Jan 8, 2023 | 12:04 AM
Wow yeah, those gaskets would not have worked at all. Major leakage indeed.
AZRR
Range Rover L322 (3rd Gen)
Jun 11, 2023 03:01 PM
2foot2los
May 19, 2022 09:03 PM
El Duce
Apr 26, 2017 12:23 AM
detcodisco
Mar 4, 2010 06:49 PM
D1 Austin
Feb 12, 2009 08:51 AM
