H8 battery fit question
Just replaced an old smaller H7 with a new Interstate MTP-49 H8. Fit the tray alright and the leads fit well but the battery tie down bracket doesn't seem to fit as well. Anybody have a similar issue? The "cap" portion on the interstate seems to be a different shape. The base of the battery also very slightly obscures one or the other threaded holes that receive the bracket screws. Making sure I'm not doing something wrong. TIA
I currently have a Duracell Platinum AGM H8
Sure they were tight getting in, but everything fit fine and bolted down easily once in place (4.4 V8)
. . . maybe you accidentally rotated the strap 180º? and the battery is oriented correctly? (I know, just checking)
I vaguely remember that it only goes in 1 way - and 1 bolt may be shorter than the other - but I could be confusing this with my other car
Originally Posted by douglastic
I've had 2 Interstate H8 - I forget which exact sub-model (but I can check my old invoice tonight to confirm)
