Head Gasket Replacement
Old Aug 19, 2019 | 12:41 PM
Bryant Iverson's Avatar
4th Gear
Default Head Gasket Replacement
So after a lot of testing (Leak down, pressure and chemical block tests) its looking like I have a blown head gasket (and possibly cracked block/head or slipped sleeves). Looks like HG kits run about $500 so I was going to just pull the heads and see what is actually going on under there. Ive done HG jobs on other vehicles and used other forums for tips and suggestions but I cant find anything anywhere about anyone doing a head gasket replacement on a 4.4. Anyone have experience with these and can recommend a good shop manual with the details (torque sequence etc.) and any special tools needed?
Old Aug 22, 2019 | 10:23 AM
4th Gear
So after more research, I found all the manuals and special tools needed but decided that I'm just going to replace the entire motor. After all is said and done, doing the job myself, I'll be into it at least $900 not even knowing if there's other problems from the overheat whereas I can get a tested used motor with less mils for +/-$1300.
Old Aug 23, 2019 | 11:47 AM
abran's Avatar
sounds like a solid plan. The one thing that kicks everyone's A$$ is getting the driver side motor mount bolts, you have to remove the steering linkage.
Good luck.
Old Aug 23, 2019 | 12:01 PM
4th Gear
Good luck.
Thanks! I saw your post about removing your motor without taking off the body, I was excited to see that someone else had done this because that is what I was going to try. Ive done motor swaps on other vehicles, but other than the steering linkage, were there any other oddities or anything else you can recommend? Where did you end up strapping the cherry picker to on the engine?
Old Aug 23, 2019 | 12:43 PM
abran's Avatar
I cant remember exactly. Let me think about it.
Old Apr 17, 2020 | 03:17 PM
Charliegeosci's Avatar
Hey there,
can you link me to the guide about doing the replacement of the head gasket? Lmk pls. I’d love to take a look, because mine is blown.
_ExpeditionMan
Apr 24, 2019 05:07 AM
Gnomadf
LR4
Dec 21, 2018 02:23 PM
eskiltell
Jun 15, 2018 09:28 AM
jaredj
Dec 19, 2014 08:13 AM
dave41
Aug 2, 2010 04:42 PM
