How to tell if lock cylinder needs to be replaced?
Old Apr 14, 2022 | 10:25 PM
Fade89away's Avatar
5th Gear
Default How to tell if lock cylinder needs to be replaced?
So my 2009 lr3 has a new battery and alternator, but when I go to start it sometimes, it’ll click at me like the battery is dead. I have to totally remove the key and reinsert it (sometimes a couple times) for the car to then start properly. No fails or lights are coming up during all of this and someone suggested it might be the lock cylinder. Does that seem like a logical possibility? Or do I need to be looking at something else.
also, the alternator and battery both check good so I know those aren’t going/bad.
Old Apr 15, 2022 | 08:04 PM
DakotaTravler's Avatar
Could easily be the starter.
Old Apr 16, 2022 | 05:38 PM
Fade89away's Avatar
5th Gear
Silly question, is that part of the lock cylinder or something totally separate?
Old Apr 17, 2022 | 12:50 PM
tracyc's Avatar
The starter is a small motor attached to the engine that spins to start it. So, no, not part of the key cylinder.
Old Apr 20, 2022 | 08:45 AM
Fade89away's Avatar
5th Gear
How would I best go about figuring out which could be going and are they easy to change out myself?
Old Apr 20, 2022 | 05:00 PM
Not hard, not easy. But since you did not even know what a starter is I very much recommend having someone else do it. You are dealing with battery and starter connections when doing it and you do not want to mess those up.
Kolbywan
Jan 20, 2018 09:14 PM
Garover13
Oct 13, 2014 02:11 PM
DISCOENO
May 2, 2014 12:45 AM
mastercars
May 4, 2010 03:16 AM
briauna2003
Aug 15, 2008 08:37 AM
