Intermittent starting issue
UPDATE:
I finally broke down and took the truck to a mechanic about this starting issue. He indicated it was a failing relay and that he replaced and it was good to go.
And so it was for about Four weeks. But now it’s started to the intermittent starting issue again. I would not expect a relay to fail that quickly unless something is causing it to fail. Any thoughts on what I am fighting here?
So I’ve tried a new relay and tried the headlight washer relay and it hasn’t helped. When I turn the key to start I hear a click but then nothing. In order to try another start, I have to turn the key all the way off and try again to get that click. Sometimes it takes 6 or 7 tries but it will finally start. Sometimes it will engage the starter but struggle, like the battery was bad and it’s not getting enough juice. Then it will start after a few more tries.
I’m at a loss. It’s not acting like a bad starter that is gradually failing. Usually it’s all or nothing. Meaning it either turns over or it doesn’t. Any thoughts?
Starter turning over slowly suggests a bad electrical connection. Even a small bit of corrosion on a high amperage circuit will drop a lot of voltage. Take off all cables, including grounds, clean and tighten down.
That’s what I was afraid of. Everything is good on the top side. I’m guessing it’s at the starter itself which I see is a bear to get to. Given I don’t have a lot of time right now, it’s likely going to the mechanic to check. Hopefully just a little corrosion.
Different; it's what makes a Rover, a Rover.
