Intermittent starting issue
Old Jul 25, 2024 | 06:47 PM
loanrangie's Avatar
Originally Posted by Columbiar
UPDATE:
I finally broke down and took the truck to a mechanic about this starting issue. He indicated it was a failing relay and that he replaced and it was good to go.
And so it was for about Four weeks. But now it’s started to the intermittent starting issue again. I would not expect a relay to fail that quickly unless something is causing it to fail. Any thoughts on what I am fighting here?
Try a new relay again and see if it goes backing to starting properly, if it does then there is possibly something overloading the relay causing it fail.
Old Aug 17, 2024 | 10:59 AM
Columbiar's Avatar
So I’ve tried a new relay and tried the headlight washer relay and it hasn’t helped. When I turn the key to start I hear a click but then nothing. In order to try another start, I have to turn the key all the way off and try again to get that click. Sometimes it takes 6 or 7 tries but it will finally start. Sometimes it will engage the starter but struggle, like the battery was bad and it’s not getting enough juice. Then it will start after a few more tries.
I’m at a loss. It’s not acting like a bad starter that is gradually failing. Usually it’s all or nothing. Meaning it either turns over or it doesn’t. Any thoughts?
Old Aug 17, 2024 | 11:03 AM
Gordo51's Avatar
Starter turning over slowly suggests a bad electrical connection. Even a small bit of corrosion on a high amperage circuit will drop a lot of voltage. Take off all cables, including grounds, clean and tighten down.
Old Aug 17, 2024 | 01:30 PM
Columbiar's Avatar
That’s what I was afraid of. Everything is good on the top side. I’m guessing it’s at the starter itself which I see is a bear to get to. Given I don’t have a lot of time right now, it’s likely going to the mechanic to check. Hopefully just a little corrosion.
Old Aug 22, 2024 | 12:50 PM
Columbiar's Avatar
Update, it needs a starter. So hopefully that will fix the issue.
Old Aug 26, 2024 | 12:54 PM
Columbiar's Avatar
New starter installed and the issue has so far been resolved. It’s just very odd how this all happened. I’ve had starters on other vehicles go out before and this was different.
Old Aug 27, 2024 | 03:16 PM
DoryBreaux's Avatar
Different; it's what makes a Rover, a Rover.
Old Aug 27, 2024 | 05:40 PM
Columbiar's Avatar
Good point.
Columbiar
Mar 22, 2024 10:07 AM
Disco99SD
Aug 19, 2023 08:24 PM
Rover Hood River
Jun 6, 2022 04:57 PM
jigray3
Jun 24, 2014 05:35 PM
eimeo98
Mar 5, 2007 12:07 PM
