Land Rover Discovery 3 One headlight not working
Old Aug 14, 2018 | 09:29 AM
HollieRebecca93's Avatar
Default Land Rover Discovery 3 One headlight not working
Hello,
Posting on behalf of my dad who owns a Land Rover Discovery 3 SE, 2005. Current problem is that the drivers side, dipped beam headlight isn't working. Main beam, sidelight and indicator all work and if i plug the headlight into the passenger side everything works fine, i've checked all fuses, changed some just in case but it's still not working. Any ideas?
They are Bi-Xenon and yes i've tried new bulbs just in case.
T.I.A
Hollie
Old Aug 14, 2018 | 09:59 AM
abran's Avatar
Check for corrosion at the back of the bulb connector.
Old Aug 14, 2018 | 06:29 PM
DakotaTravler's Avatar
From what I have read, the lamps themselves last a long time. Until I changed mine a couple months ago, they appeared to still be factory at 110k miles. The date codes were from 2006! And they both still worked fine, I changed for maintenance sake. However, the ballasts seem to fail more often than the lamps. So there is the possibility that the ballast has gone bad. Aftermarket ones are inexpensive and the inexpensive "Phillips" are often cheap copies. So, beware.
JBEGIN
Dec 14, 2013 05:38 PM
aguison
Nov 8, 2012 06:18 AM
Ranchrover
Aug 19, 2010 07:37 PM
humroot
Feb 28, 2009 10:36 PM
snugg
Dec 16, 2008 10:03 PM
