LR3 2007 V8 Air Conditioning Issues
Old May 19, 2026 | 10:21 PM
  #21
Monochromeak's Avatar
Well if you must know, I did it like this...... The fan removal, can be easy or hell. Depends. Mine is always easy cause I take it off often and I put on a good dab of anti-seize.
https://landroverforums.com/forum/lr...tricks-125918/
wow. Nicely done. I will use this as guide Is the fan removal required?
Old May 19, 2026 | 10:22 PM
  #22
DakotaTravler's Avatar
Yes, fan must come out. Remember the threads are REVERSED!
Old May 19, 2026 | 10:23 PM
  #23
good note to remember. This is on my Thursday docket when the parts arrive.
Old May 19, 2026 | 10:29 PM
  #24
But if you do not mind having to refill the system, removing the radiator completely is also an option. It comes out super easy and you can leave the fan. The only issue will be the lower fan shroud but you can probably leave it below, lift the radiator out then pull the lower shroud up away form the fan. Never tried it, but I would think that would work. Then the condenser will be easier to work out too.
Old May 23, 2026 | 05:36 PM
  #25
Haven’t been able to get the fan out yet.. are we 100% it’s reverse thread. (So loosen to right if facing the vehicle from the front). If so this thing must be in there quite good haha
Old May 23, 2026 | 06:12 PM
  #26
Yes, reverse. So you will work it clockwise to loosen it as you face the engine, to the right. Obviously locking the fan pulls so it does not spin. An air chisel or the like can help to spin the nut and break it free. When you put it back on, just snug it up cause the engine will tighten it as things spin.
Old May 24, 2026 | 09:52 AM
  #27
DimaPVD's Avatar
Any ideas if the receiver-dryer can be replaced without completely removing condenser?
Old May 24, 2026 | 10:43 AM
  #28
I do not think easily at all. Prop have to pull the radiator. After I rebuilt my AC I wanted to do that, dump the system and replace the drier incase it caught a lot of gunk somehow. Just being paranoid really. But also saw it would have been a total pain to do without moving a ton of stuff. I did try to position the clamp nut that holds the drier strap to the condenser in a position making it easier to remove/not buried.
IanInJordan
Feb 8, 2018 05:41 PM
noahssracer
Jul 10, 2017 03:10 PM
mitschweigert
May 15, 2014 05:34 PM
jalodge
Apr 30, 2014 02:47 PM
simpson lr3
Jun 4, 2012 06:14 AM
