LR3 Transmission Fault Code
Old Jan 11, 2020 | 07:12 PM
DerekBrownell's Avatar
3rd Gear
Default LR3 Transmission Fault Code
I have a 2005 LR3 with 119,000 miles. It drives great for 30-40 minutes then goes into Transmission Fault mode when lightly pressing on the gas(under 2000 RPM's ) If I accelerate rapidly, no problem, it goes through all the gears smoothly. I have also had all the lights on the dash go on on longer drives. I have changed the filter and fluid recently.
Old Jan 12, 2020 | 03:18 AM
Globetrotter448's Avatar
Could be low on fluid especially if not topped up whilst engine running, alternator/battery not charging properly
Old Jan 12, 2020 | 02:58 PM
3rd Gear
I had a shop make sure to top off the Fluid. The shop also got a couple codes. One was the brake light switch, the other was a transmission code regarding gear ratio (he had never seen it before) They also replaced the battery. Could a alternator that is going bad still charge the battery but not produce the proper amps cause electrical issues? I do feel its an electrical issue. Also, how about the trans solenoids? Thank you very much for the help. I appreciate it.
Old Jan 12, 2020 | 04:21 PM
I would still get the fluid checked. The brake switch gives all sorts of problems and is cheap to purchase so would change that as well.
Old Jan 12, 2020 | 08:24 PM
loanrangie's Avatar
Failing seals on the valve body and shift solenoids can cause the " incorrect gear ratio " trans error.
Old Jan 12, 2020 | 09:55 PM
3rd Gear
Does that mean a transmission rebuild? Or can you replace parts while the trans is in place?
Old Jan 12, 2020 | 10:59 PM
You can purchase seal and solenoid kits to rebuild it. If you have a hoist you can remove the necessary bits (valve body) but there are a few "gotcha's" when putting it back in. Most people would possibly add a new "mechtronics" bit as well.
TheVolunteers
Dec 6, 2019 05:42 PM
WYRover
Jul 27, 2017 07:25 AM
Jtm123
Mar 20, 2017 10:17 AM
millydilly
Feb 16, 2016 07:54 PM
jkid
Jan 26, 2008 08:11 PM
