New to me LR3 stuck between high and low
Old Aug 2, 2025 | 05:32 PM
Nahuebsch82's Avatar
No worries. This forum does not bite off peoples heads if they ask redundant questions and stuff. Better you ask if ya want, we will answer.
Ooff topic...What's the mount for that's under the lid of the center console? Lol
Old Aug 2, 2025 | 06:04 PM
DakotaTravler's Avatar
Now I know you are under 30yo…. That is for a cell phone.
Old Aug 2, 2025 | 06:05 PM
PSH im 42 lol 😉
Old Aug 2, 2025 | 06:29 PM
Well how the heck not recognize a Nokia brick phone kit! LOL
Old Aug 4, 2025 | 07:53 PM
Are there any relay/fuses I can check that goes to the transfer case h/l selector motor?
Old Aug 4, 2025 | 08:01 PM
I am pretty sure there is not since it is a variable motor type and not simply on/off. Pretty sure it is direct wire to the ECU. I have never heard of a motor going bad, I am sure they can tho. Usually the gear strips. You can remove the motor to inspect the gear. If that reader you bought is like the GAP tool, you can rear the positions of the various transfer case bits which can sometimes hint to the issue.
Related story. I had an issue with my transfer case. It would not shift right and sometimes drop into low which caused a hell of an issue when on paved roads and going into a turn. In my case, I cause the issue by using stop leak on the transfer case. It swelled an o-ring that acts as a "clamp" on the solenoid hate seal. The o-ring went around that and prevents fluid from entering. But the leak stop swelled it and then fluid got into my solenoid and caused issues. Just bringing it up incase someone put stop leak in that case. The output seals like to leak. I have a whole new case to put in at some point.
Old Oct 15, 2025 | 11:16 PM
Sorry for the late response back, was on medical leave for a couple months. But it was the TCCM. Once that was replaced and all things calibrated no more issues!
Old Oct 15, 2025 | 11:18 PM
Nice! Thanks for the update! Enjoy the ride!
Black.Rhino
Jul 6, 2022 09:59 AM
KPatterson
Jan 5, 2021 07:16 PM
tombartley
Sep 15, 2014 06:18 AM
jalodge
Nov 10, 2013 06:35 PM
samsly
Nov 25, 2007 08:04 AM
