No-crank/no-start 2005 LR3 V8 4.4L
2005 LR3 V8 4.4L: I bought a no-crank/no-start LR3 with 123K miles, recently installed transmission, high hopes and confidence, and a lot of ignorance. 😀
The ignition will turn on but will not start. The power/cigarette light relays click open when I turn the key.
GAP IID codes are listed in the provided photo. Any suggestions where to go next? Getting a lot of “lost communications” errors across PCM, VDCM, TCM, TCCM.
Below is the list of maintenance items completed/tested:
When the ignition is turned on, one of these two relays for these two auxiliary power / cigarette lighters clicks in the Central Junction Box (CJB)
The codes listed were always after first clearing the codes
- Installed brand new battery from Costco (Interstate AGM)
- Repaired sunroof drains (drivers/passengers)
- Repaired all splices along passenger side cable
- Cleaned all connectors to CJB, TCM, and main ECU.
- Inspected all fuses/relays in CJB and under hood
- Had locksmith rekey and it was not the problem - per the locksmith
- Previous owner had the transmission and TCM replaced by transmission shop but since it was no-crank/no-start, it’s never been tested.
- Test grounds throughout
- Try to force start the starter relay (jump cable to see if it cranks)
- Turn the crankshaft engine to test engine is not seized up
- If CJB is damaged due to water, swap out CJB (VIN transfer service) from UK vendor
- Others?
