Off-road and Access lights on simultaneously
Ok. Does it matter if the steering angle LOOKS pretty reasonable (I was looking at that today as one of the live values)? Or does recalibrating it, regardless of how accurate it already is, still reset something?
I must be calibrated when installed. If it is off by only a few degrees then the truck assumes there are issues because the wheel speed sensors do not match what should be a turning truck. Take only couple seconds to calibrate anyway. Best to drive down a straight road for a hundred feet so the truck is pointed dead straight to take out any tilt you may have in the steering wheel. Unless you have a good alignment and the wheel itself does sit nice and proper. Then just calibrate it as you sit - again just make sure you wheel is exactly as it should be as if you were driving dead straight.
Still no luck. I went out and calibrated this morning before work. It was off by about nine degrees, but calibrating it didn't get rid of the three amigos. I'm starting to wonder if I'm missing passing on some important information or something. After clearing codes and rescanning I have the same three codes as always:
L319 - LR3 2006
Vehicle scanned on 14-10-2025 08:51
Using IIDTool BT V4.0 B4148
Body Control
Calibrated the steering, reread codes, same three codes and the three amigos on. (sigh...)
L319 - LR3 2006
Body Control
- B1A93-93 (2F) Invalid roof position - Component failure - no operation
( on 14-10-2025 08:51:17 at 158900 km ) - B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
( on 14-10-2025 08:51:36 at 158900 km ) - B1C57-14 (2F) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
( on 14-10-2025 08:51:18 at 158900 km )
Nice degrees is nuts. At this point, try a hard reset. Disconnect battery for 10 minutes. Lets just clear all the crap out and see if that works. From there forward we go. But I see no code that would cause your faults. That is why I suspected the steering sensor since it can be way off, cause lots of math issues but not actually generate a fault.
The only code that is odd is that low freq coil. I really have no clue what that is about. Unless the body control module is having a really bad day and causes all these other faults? It could I suppose.
Ok, I just realized that I have been posting bad information (hard to troubleshoot when the correct information isn't provided!
). I was thinking that the three dash lights that I have on are referred to as the "three amigos", but I think I have different lights on. The lights that I have on are: ABS (red), Brake systems (red), and Dynamic Stability Control (amber). These lights have been on the whole time and nothing that I have tried has extinguished any of them. I also have the Suspension (amber) on now, and it normally comes on once I start driving, but always clears when I clear faults.
I did a hard reset today. Disconnected the battery cables, waited a few minutes and then shorted them together. Left them like that for about fifteen minutes and then reconnected the battery. I had pulled the suspension fuses so just the leaky right rear corner was low. As soon as I started the vehicle the ABS, Brake systems and DSC lights all stayed on. The reservoir had leaked down a bit so the compressor fired up to bring the pressure up to 258psi. I cleared codes and then checked them and got:L319 - LR3 2006
Vehicle scanned on 16-10-2025 11:57
Body Control
I started driving and right away the Suspension (amber) light came on and the right rear corner inflated to Access height and the other three corners dropped to Access height (I'd left all four corners higher than access). I checked codes again and now had:L319 - LR3 2006
Vehicle scanned on 16-10-2025 12:03
Body Control
After driving for about twenty minutes I checked the codes again and got:L319 - LR3 2006
Vehicle scanned on 16-10-2025 13:22
Body Control
Any new suggestions with this information and my correction on which lights are illuminated on the dash? Does the ABS need to be read with a different tool, or why doesn't the Gap Tool show anything related to ABS when the ABS light is on?
Thanks!
). I was thinking that the three dash lights that I have on are referred to as the "three amigos", but I think I have different lights on. The lights that I have on are: ABS (red), Brake systems (red), and Dynamic Stability Control (amber). These lights have been on the whole time and nothing that I have tried has extinguished any of them. I also have the Suspension (amber) on now, and it normally comes on once I start driving, but always clears when I clear faults.I did a hard reset today. Disconnected the battery cables, waited a few minutes and then shorted them together. Left them like that for about fifteen minutes and then reconnected the battery. I had pulled the suspension fuses so just the leaky right rear corner was low. As soon as I started the vehicle the ABS, Brake systems and DSC lights all stayed on. The reservoir had leaked down a bit so the compressor fired up to bring the pressure up to 258psi. I cleared codes and then checked them and got:L319 - LR3 2006
Body Control
( on 16-10-2025 11:57:42 at 158900 km ) - B1C57-14 (2F) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
( on 16-10-2025 11:57:43 at 158900 km )
Body Control
( on 16-10-2025 11:57:42 at 158900 km ) - B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
( on 16-10-2025 11:58:38 at 158900 km ) - B1C57-14 (2F) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
( on 16-10-2025 11:57:44 at 158900 km ) - B1D14-15 (2F) Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
( on 16-10-2025 12:03:25 at 158900 km )
Body Control
( on 16-10-2025 12:55:55 at 158910 km ) - B1B02-28 (2F) Low frequency coil - General signal failure - signal bias level is out of range/zero adjustment failure
( on 16-10-2025 13:01:24 at 158910 km ) - B1C57-14 (6C) Passive start ignition relay coil circuit - General electrical failure - circuit short to ground or open
( on 16-10-2025 12:55:56 at 158910 km ) - B1D12-15 (2E) Volumetric alarm power circuit - General electrical failure - circuit short to battery or open
( on 16-10-2025 12:59:55 at 158910 km ) - B1D14-15 (2C) Interior lamps 2 circuit - General electrical failure - circuit short to battery or open
( on 16-10-2025 12:59:53 at 158910 km ) - U0155-87 (2C) LCD Gauge Communication Lost - Bus signal/message failure - missing a message
( on 16-10-2025 13:07:54 at 158910 km )
- C1A77-16 (0B) Valve relay supply circuit - General electrical failure - circuit voltage below threshold
( on 16-10-2025 13:01:26 at 158914 km )
Thanks!
