P2525 Engine Code - 2008 LR3 V6
Old Jul 13, 2019 | 02:58 PM
Derek Bird's Avatar
Default P2525 Engine Code - 2008 LR3 V6
I changed the plugs, wires and coils. Bank 1 has a rough idle, and random missfires between 1 / 3 / 5.
P2525 - Vacuum Reservoir Pressure Sensor Circuit.
If I reset the codes, the only error message that appears is P2525.
What can I look at to troubleshoot this? 1/3/5 should be the passenger side.
2008 LR3 V6. Help!
Old Jul 14, 2019 | 04:22 AM
Globetrotter448's Avatar
This is more likely the crankshaft position sensor which on a petrol V6 is at the rear of the engine on the LH side
Old Jul 18, 2019 | 10:38 PM
5280LR3's Avatar
Was it mis-firing before you changed out all that stuff?
Crank sensor is actually on the transmission bellhousing. left side, about 10 o'clock ish, a 1 1/2" or so from where the bellhousing connects to the engine. Don't understand why that would only affect 1/3/5 only though. Unless someone damaged the tone ring on the flex plate. Mine ran crappy off idle and would stall occasionally after filling up... changed out the EGR and engine was a happy camper... again, no correlation to your 1/3/5 mis-fire. Check the harness that follows your coils down the center line of the engine. It y's out to ground (I'm assuming) the center coil on each side.
Old Jul 23, 2019 | 07:38 PM
Derek Bird's Avatar
Still troubleshooting... 1/3/5 is not causing check engines anymore, however does appear sometimes when idling in gear. Read on another forum spark plug wires should me 7mm, currently there are 8mm on it. We ordered a set of 7mm and see if that helps the idle ... The car also sat for a while before we bought it, we are running injector cleaner through a few tanks as well.
More to follow after my wires come in.
sickws6
Feb 24, 2020 12:28 PM
discocrazied
Feb 4, 2012 11:05 AM
tsuami1
Feb 15, 2011 06:59 PM
jasons
Aug 17, 2009 11:50 PM
hunkslam
Jun 18, 2007 05:27 PM
