Rear AC blowing warm
Old Jul 16, 2010 | 03:50 PM
traviswright's Avatar
Default Rear AC blowing warm
I have an '05 LR3 HSE, and the rear air started blowing warm yesterday. The center console still blows cold, and I have checked the dash and rear control panels to ensure they are set properly. Does anyone know if there is a seperate refirgerant charge for the overhead and Cargo compartment AC? Any other thoughts on what might cause the air to blow warm?
Old Jul 18, 2010 | 08:48 PM
Rovin4life's Avatar
same charge but its possible the rear condensor is bad or something else.
usually a leak will affect the front as well.
take a look at the codes to see what is going on.
Old Jul 19, 2010 | 10:53 AM
Good idea to check the codes... Do you know where the rear condenser is located? I might just take a closer look to see if I see something obvious.
Old Jul 20, 2010 | 06:17 AM
Rovin4life's Avatar
lr corner under the trim in the back. best you can look for is a leak. or missing connectors.
nahtanoj
Nov 14, 2013 05:02 AM
gundog
Mar 14, 2013 12:57 AM
FightOnUSC79
Jun 30, 2011 12:52 PM
disco524
Aug 1, 2010 12:02 AM
Darover
Aug 28, 2007 03:01 PM
