Reverse Mirror Dip
Old May 20, 2008 | 06:38 PM
bribake's Avatar
Default Reverse Mirror Dip
Just wondering if reverse mirror dip only works in certain modes or if it should work whenever I go in reverse. It is turned on in settings and the adjustment **** is switched to the left; but the mirror does not change at all when I am in reverse..any ideas?
Thanks-
Old May 20, 2008 | 10:23 PM
roverguy7's Avatar
Default RE: Reverse Mirror Dip
you need to have memory seats, first off, past that, there is a chance you will need to program it, to do this go into reverse, set the mirror where you want it to point, when dipped, and hold the memory button for 3 seconds, display will say stored after a chime
Old May 21, 2008 | 12:03 AM
bribake's Avatar
Really? I don't have memory seats, that's wierd they would allow it to be turned on or off in the settings if it isn't even an option. I have an '05 SE?..Thanks for the info.
Old May 21, 2008 | 07:12 PM
roverguy7's Avatar
yeah, all of the i/p are the same, so it has the option to change it in your configuration file, even if you car doesnt have what the option to be configured. one of the down sides to having 20 plus different and mostly independant computers in a car
Old Jul 20, 2011 | 01:18 PM
sprale's Avatar
Is there a way to simply override the feature?
Old Oct 28, 2012 | 08:55 PM
frederickshepard's Avatar
3rd Gear
i'd love to override the feature as well! Let me know!
Old Oct 28, 2012 | 10:24 PM
Quinten's Avatar
I don't have an HSE with this, but in my BMW you just select the passinger mirror on the switch to adjust them and keep it on theat side for default. If it's on the pass. side, the mirror doesn't dip. give it a try.
Old Jun 4, 2022 | 03:07 AM
lloydcmb's Avatar
4th Gear
legend thank you! That worked well
luttrell31
LR2
Jul 1, 2014 07:32 AM
wastedincome
Dec 27, 2012 10:19 AM
bentonrover
Freelander
Jan 3, 2010 02:52 PM
03discoman
Oct 29, 2009 10:47 PM
rangeroverboi
May 17, 2006 07:10 AM
