Steering
Slow down - take your time.
I note this is your first post so I assume you are new to your 3. I would suggest you spend a couple of weeks researching the steering system before you touch it.
You will discover the 3 is no 52 Chev and any procedure that would seem normal, proper, reasonable, correct, or intelligent is usually wrong and causes continuing problems.
All the fluids are exotic, hard to determine, difficult to source, and generally a great subject of debate.
Search the various forums for Steering Wheel shaft U joint which is located above the brake pedal - it seems to be a source of problems - needs lubrication or replacement, and then all is well again.
But please, take your time - it is the worlds first electronic 4x4.
Land Rover, making mechanics out of drivers since 1948.
ForeverBroken (08-02-2020)
jycsalas
04-17-2009 03:21 AM
Evian
08-19-2005 12:34 AM
