Stumped... No power to climate controls
Old Jun 23, 2019 | 11:52 AM
SteveTheRover's Avatar
Default Stumped... No power to climate controls
Hi, I have a 2005 LR3 4.4L and about 134,000 miles. I've been trying to solve the problem of not having any power being sent to my climate controls. I've checked the fuses under the hood and in the central junction box but all related fuses are in good shape. Popped out the climate control module to check for loose connections but everything seems to be in place. I do have a check engine light on giving me the codes P0072 (ambient air temperature - low circuit input) and U0151 (Lost Communication with Restraints Control (RCM) Module). The second code seems unrelated but do you think the P0072 code could be related to my loss of power to the climate controls? Any help would be appreciated!
Thanks,
Stephen
Old Jun 23, 2019 | 08:34 PM
abran's Avatar
Are you sure that you are testing/diagnosing this properly? Hope that doesn’t sound off
just, do you know for a fact that there is no voltage to the climate control panel?
and if you have tested/ confirmed that with an electrical diagram, have you double checked all related fuses?
Old Jun 24, 2019 | 12:18 PM
I haven’t directly checked the wires with a multimeter yet but the climat control panel doesn’t respond or light up at all. The panel itself could be bad but im not sure how to check that. Do you know where I could find a wiring diagram to refer to?
Old Jun 24, 2019 | 11:58 PM
abran's Avatar
I think you missed a bad fuse.
ill try to remember to post a diagram tomorrow.
but, I’m pretty sure it’s a fuse.
Old Jun 25, 2019 | 12:02 PM
abran's Avatar
Old Jun 26, 2019 | 09:49 AM
Thank you! This is a big help! From what I can tell from the diagrams, I should check fuses 12/13 (hard to read) 51, 59, and 22?
Old Jun 26, 2019 | 10:41 AM
YOU WERE RIGHT! It was one of the fuses that I overlooked that was labeled for the AC. Replaced the fuse and everything works now. Thanks Abran for the help!
Old Jun 26, 2019 | 11:45 AM
abran's Avatar
My pleasure. I always dread that its something difficult and start looking at the worst case, then I remind myself that its the simple stuff normally.
Old Jul 20, 2019 | 08:20 AM
Larryf's Avatar
3rd Gear
Default 2008 LR4 Climate Control
Our 2008 LR4 AC stopped working yesterday.
what I’ve noticed is that the temp control ***** are not illuminated .
The Belt is Fine
The 10 Amp F 51 fuse is good.
The 25 Amp #7 fuse is good.
im not sure where to look
Old Mar 19, 2020 | 04:24 PM
Emeka Ndubuisi's Avatar
Please what fuse exactly?
Thanks
SteveTheRover
Nov 24, 2019 07:16 PM
gulfstream69xr7
May 3, 2017 07:27 AM
sstevensonm
Jan 7, 2014 08:14 PM
pkppunk
Oct 5, 2013 04:00 PM
LRDISCO75
Mar 13, 2012 10:17 AM
