Suspension clunk
Old Dec 14, 2015 | 07:02 PM
pgoodrich's Avatar
At least I hope I found the source of the clunking. I will keep you all posted.
Old Feb 8, 2016 | 04:02 PM
pgoodrich's Avatar
After removing the struts and inspecting the bushing it was ok. There were no cracks just bent at that angle giving the illusion of a crack. I removed the upper control arm and found them to be gone, couldn't tell when installed. I replaced them with the polybush as well and all has been good with that. I just had to replace the rear wheel bearing last month after returning from trip to UT. That was a fun project and $150 bearing from LR.
Old Feb 8, 2016 | 06:37 PM
DavC's Avatar
Sway bar bushings are cheap and easy (except for one bolt that you need to get at from the engine bay), but I believe the main symptom for them going bad is vibration in steering wheel especially in turning (I could be wrong). I used to have that issue and then changed the bushings, completely forgot about the vibration ever happening.
Old Feb 9, 2016 | 11:46 AM
houm_wa's Avatar
Sway bar bushings make a "clunk" as well but it's different. It's more of a dull thud and happens at fairly low speeds over potholes or speed bumps that induce body roll, which makes sense. Hit a speed bump straight on...no clunk.
DiscoMike2003
Nov 13, 2008 04:57 PM
Airwolf1
Nov 13, 2006 03:42 PM
Airwolf1
Nov 11, 2006 10:36 PM
msbont
Sep 10, 2006 03:53 PM
bmartin2
Feb 18, 2006 02:49 AM
