What did you do to your LR3 today?
Old Nov 23, 2020 | 10:06 AM
  #1511
Amadreas's Avatar
Default Starting some general maintenance
Replaced all the spark plugs, easier then I read. Broke the PVC hose (brittle) and repaired it with duct tape until the new one arrives. Cleaned MAF sensor and throttle body. Changed air filter and cabin air filter. Engine was idling rough and stalling on start up. Popped the hood looking for the issue at the pvc hose and TB electrical connector, then realized I forgot to replace the oil cap onto the filler after replacing the top engine cover.
Old Nov 23, 2020 | 11:22 AM
  #1512
used it as a mobile office for some land navigation training
Old Nov 23, 2020 | 02:59 PM
  #1513
Amadreas's Avatar
Default Changed front differential breather to updated version
Pick up a new updated front differential breather. $30.00 Canadian at the LR dealer in Richmond, BC.
Installation is easy.
Old Nov 27, 2020 | 07:07 PM
  #1514
Put the LR3 to work today cleaning up out in the woods. Clearing tree's off a power line and on the path. Than pulled out a trailer loaded with junk that was on 2 flat tires sank to the axle in the earth. We worked our turkey dinners off today.
Old Nov 27, 2020 | 07:34 PM
  #1515
soarvet's Avatar
Went bouncing around looking at some land we picked up out in the country
Getting ready for retirement huh...
Old Nov 27, 2020 | 07:47 PM
  #1516
You know it, about a year and a half to go
Old Nov 27, 2020 | 09:26 PM
  #1517
loanrangie's Avatar
Nice bit of bush there AR.
Used the D3 and its winch to pull out a tree which saved me a lot of digging, only 28C but high humidity.
Old Nov 27, 2020 | 09:41 PM
  #1518
Thank you Sir, got a long road to go on clean up, but the price was right that it made the sweat equity worth it. Not huge at 3.5 acres. There is 4 abandoned cars along with that trailer above and a 4wheeler, on the property my winch will be getting a work out as well pulling them out. There are a couple trees that might feel the tug of the Warn as well.
Old Nov 30, 2020 | 10:37 AM
  #1519
Amadreas's Avatar
Default Armrest repair
Repaired the floppy drivers armrest. Removed the armrest and replaced the roll pin.
Old Dec 3, 2020 | 11:37 PM
  #1520
loanrangie's Avatar
Picked up a used Llams unit of someone upgrading to the Xlifter, mounted the switch and will plug the module in tomorrow.
