What did you do to your LR3 today?
Old Nov 12, 2020 | 02:33 AM
  #1501
loanrangie's Avatar
Originally Posted by Rufflyer
No they are both connected to the body ground, but are not tied directly together. I have a Traxide aux battery system for that.
Now, it won't start unless it is on jumper cable to another running vehicle. I ordered a new starter relay. it will be in this afternoon, but I fear it may be the starter solenoid.
I will keep you informed.
Jeff
Some models of the Traxide unit have the linking feature for self jumping but i was a tight **** and got the basic unit which works for me, worst case i just undo the cables and bypass the controller for jumping.
Old Nov 12, 2020 | 10:38 PM
  #1502
DakotaTravler's Avatar
Or just jumper cables from one battery to the other!
So today was interesting. I have never removed a body harness from an LR3 before. I hoped for more connectors but there were far, far less than expected. First it is a wrecked vehicle, so the interior was pretty much gutted. This would have had to be done anyway. Second the owner is transferring the prestige dash from the wreck to the new truck. So he had pretty much gutted the dash and removed the cover, this is also required. But we managed to get it all out. Some of the wiring logic seems odd, for example they run a large bundle from the junction box back around the rear of the front seats just to go forward again then up the A pillar to the roof. Yet the driver door winds through the dash. It would have been easier to run the roof stuff straight up the passenger side a-pillar, would have cut 12 feet off the run. And that driver door harness, you pretty much can not route it around the dash for removal with the top dash on. So I was very glad we had it off.
So now we just need a few days to transfer the harness and get the rest of the interior moved over. The new truck's interior was alpaca beige and trashed beyond belief. The wreck was a flawless black interior, so he wants it all moved over, carpet and all.
Old Nov 13, 2020 | 06:52 AM
  #1503
Rufflyer's Avatar
I ordered the ground cable.
We will see if it makes a difference.
Old Nov 13, 2020 | 11:53 AM
  #1504
soarvet's Avatar
Replaced front and rear wiper blades and installed the Proud Rhino Power panel to replace the ashtray and 2 12v. adapters.
Old Nov 13, 2020 | 01:56 PM
  #1505
Blackngold77's Avatar
Replaced my coolant overflow tank. Pretty easy job minus siphoning out all the fluid from the old tank
Heads up, Amazon has Royal Purple fluids cheap right now. Got a 3 pack of Max Gear for $45, it's usually 20 a bottle in stores
Old Nov 18, 2020 | 09:40 PM
  #1506
Went bouncing around looking at some land we picked up out in the country
Old Nov 20, 2020 | 02:57 PM
  #1507
T3rover's Avatar
Default Researched
Originally Posted by jafir
I installed an electric brake controller with using the Ford plug. Now I just need to borrow my buddy's trailer and put the defender on it to see how well an LR3 can tow it. If it works well, maybe I'll start going to some more rover events soon!
I’m looking for a plastic stone guard for the round driving lights. Don’t seem to sell them separately anymore. Any suggestions?
Old Nov 20, 2020 | 06:07 PM
  #1508
Motoprophet's Avatar
Default Fixed some electrical gremlins
I was having random, but increasing, transmission faults, suspension faults, lost communication with vehicle etc. I checked the battery with the car not running and it was 12.2. When the LR3 was running it would slowly drop to 11.5. I changed out the alternator 4 days ago and not one issue since. The battery now reads 12.9 not running and 14.4 running. Yes!!!
Old Nov 21, 2020 | 06:54 PM
  #1509
soarvet's Avatar
Rebuilt my Hitachi compressor today with a kit from 4x4AirSeals over in the U.K. Great kit. I almost switched out to coils. I think I’ll hold off for a while at least. Next on the list, new control arms in the front.
Old Nov 23, 2020 | 07:05 AM
  #1510
jbullock78's Avatar
I didn't do anything to my LR3- But rather used it in proper fashion in Western MD-
Glamour Shot-
Trying new trails- fresh tracks and a little muddy -
