Whine from trans or front diff
I have a 2006 LR3 SE and I noticed a loud whine coming from the front. I immediately thought it was the transmission, but am now wondering if it is the front diff. The transmission shifts perfectly with no hesitation or slippage and I assume if there were an issue it would not work so well.
Will the diff whine if it is going out? I have read several posts on finding new/rebuilt ones on this forum. If it is the diff, how much am I looking at for rebuilt and can the current one be rebuilt?
95% chance the whine is coming from the wheel bearings. My LR3 has 142k miles ('07 SE V8) and makes the same noise. Changed FR/RR diff and T-Case fluids. Used Castrol Syntax 75w90 for diffs and Royal Purple Synchromax for T-Case. Fluids were black as shoe polish. Whine continued. So now my next step is to replaced all four wheel bearings/hub assemblies with SKF or Timken units. I am also going to replace the driver's CV axle as the thread for the axle nut were badly damaged when I replaced the control arms. And while I have the truck in the air, I am planning on replacing the sway bar links and the sway bar bushings.
I may be asking without doing enough research, but are the wheel bearings replaceable without replacing the entire hub? when I search for D2 wheel bearings I get a bunch of hits for full hub assemblies.
For example, the rear wheel bearings need to be pressed in.
the bearings are around $80 a piece. The entire knuckle needs to be removed, hub pressed out, bearing pressed put, bearing pressed in, hub pressed in, knuckle replaced and an alignment done.
unless you have a shop press and don't value your time, it's better for your wallet.
DISCO JAK
Aug 15, 2013 11:12 AM
tsuami1
Jul 15, 2010 09:39 PM
The People Family
Aug 6, 2008 10:32 PM
