2014 LR4 transmission
Old Aug 23, 2023 | 06:36 PM
Jrr2091's Avatar
New Member
Default 2014 LR4 transmission
I have 2014 lr4 with 88k. Owned 5yrs. Got transmission fault and took to specialist. Won't engage gears. Seems that the transmission valve body is bad and cost to replace is 6k+. My question is can you replace the whole thing with a used transmission that comes with valve body attached? I'm being told that you can't bc won't be able to program correctly. Is that correct? Used transmission with its valve body attached is like $1600 and I was hoping to go that route.
Old Aug 27, 2023 | 12:45 PM
abran's Avatar
Used trans is always a gamble, entire unit rebuilt and installed here is $8500.
if you go used, you will need to switch the Mechatronics from your old trans to the donor. It’s the black plastic assembly in between the valve body and trans.
Old Aug 28, 2023 | 06:49 AM
guy's Avatar
guy
Are they “a specialist” because they charge too much?
A transmission valve body is transferable… but I suggest, if you have a ZF transmission service center near you, get another inspection and quote. The last time I have my valve body (on a Jag) overhauled, it solved all my problems. And it was not expensive.
Louis Limoges
LR4
May 3, 2023 08:02 AM
Justin Ruiz
LR2
Jul 16, 2021 07:03 AM
cwrobo
Jul 15, 2020 01:46 PM
RRJon818
Mar 26, 2020 09:31 PM
