Door cable replacement
Old Sep 28, 2023 | 03:58 PM
malibumike's Avatar
Default Door cable replacement
I need to replace the cable that opens the door from the inside of a LR4. This is the cable that clips in to the back of the door card handle, runs thru a black rubber round grommet in the metal door, then attaches to the assembly that is hidden. I see the cables for sale. With the door card off, will I be able to install the end in to the assembly or will I need to remove the window? Im unsure about access. This is the part and cable I'm working on. The cable that needs replacing is the one with th round rubber grommet on it.
Old Sep 28, 2023 | 09:09 PM
keninnc's Avatar
You will need to remove the window actuator but not the window. After the inside door panel is removed the big speaker needs to be removed so you can unclip the widow from its actuator.
Then you will need to remove the door latch actuator.
Here is a picture of how the cable you are replacing connects to the door latch actuator.
keninnc
Jul 24, 2021 07:41 AM
rich.cash
Mar 9, 2021 03:43 PM
awoods82
Mar 17, 2012 08:00 PM
ColoDisco
Jul 26, 2011 06:28 PM
hag1128
Nov 8, 2010 11:49 PM
