Head gasket repair costs
Old Oct 24, 2025 | 07:27 PM
expedio2005's Avatar
Default Head gasket repair costs
I just got a quote from my Indy European car specialist for a head gasket repair. What would you say is an appropriate amount to expect for this job? While doing it, I asked about doing the timing chain. Thoughts on price for this also? Here's the quote below"
Remove & Replace Cylinder Head Gasket
Tech: B Reed
Labor Total
Remove & Replace Left and Right Cylinder Head Gasket $6,876.86
pressure test and mill $1,014.55
Part Qty Total
ESP Cylinder Head Bolt 1 $16.65
ELR Cylinder Head Gasket 1 $56.42
ELR Cylinder Head Gasket 1 $63.97
OES Timing Chain Tensioner 1 $268.97
OES Timing Cover 1 $261.83
ESP Spark Plug Tube Seal Left 3 $85.53
RIN Valve Cover Gasket 1 $42.44
RIN Valve Cover Gasket 1 $39.39
ESP Spark Plug Tube Seal Right 3 $135.99
ELR Intake Manifold Gasket 2 $58.00
ELR Intake Plenum Gasket 1 $104.29
ELR Oil Cooler Seal 1 $22.35
CFW Gasket Maker 80ml Tube 1 $15.31
ELR Exhaust Manifold Gasket 1 $72.03
OES Exhaust Gasket 2 $82.96
parts 1 $1,309.00
CFW Valve Stem Seal 20 $95.20
Subtotal
$11,317.24
Est. Tax
$309.18
Job Total
$11,626.42
They said adding on the timing chain replacement would add up to another 3k or so.
Is this in the correct ballpark or is this significantly high? There is antifreeze in cylinders 1 and 4 but the cylinders walls are smooth and not scored or scratched.
Old Oct 25, 2025 | 10:18 AM
guy's Avatar
guy
15k. Holy cow. I was under the impression I could get a factory rebuilt engine for that... with a 1 year parts and labor warranty.
Of course, there is much more scoped here than just the head gasket change. Has your Inde read the workshop manual? Or done the job before?
Cheers!
Old Nov 3, 2025 | 10:44 PM
thebruce's Avatar
I think thats legit cost, probably very reasonable in parts of the country. How much are they billing per hour?
ive just taken the valve covers off my 2016 LR4, which is maybe 85% of the removal effort of the head gaskets, but I have no idea the additional installation effort required. I assume quite a bit.
I can tell you that removing the supercharger is actually much faster than shops bill it out for. Ive seen videos of guys removing it in 30 mins, but they have all their tools lined up and have done it 50 times. The coolant cross over job is actually super easy and quick once you know what you are doing. The majority of the time on the valve covers, and presume the head gaskets, is the prep time for the re-installation: new injector seals, cleaning and installing new gaskets on the valve covers, etc. It's a lot of little small meticulous things that add up.
Old Nov 7, 2025 | 12:10 PM
The shop I took it to I believe is $230 per hour. I've had 4 quotes by different shops and one was $7900 but the rest were $10-$14 for head gaskets and timing chain.
Discorama
May 7, 2023 06:18 PM
Bob Loblaw
Apr 23, 2013 09:17 PM
me 2
May 8, 2012 12:57 PM
04BluDisco
Jan 15, 2012 10:15 PM
adigerol77
Jul 31, 2011 01:40 PM
