Laggy Accelerator Fix?
Old Nov 11, 2020 | 06:53 PM
  #171
BritCars's Avatar
What's the engine on your car? This issue was only on earlier Si6 Discoveries and fully resolved by a transmission software patch a year or more ago.
Old Nov 12, 2020 | 11:09 AM
  #172
Doty's Avatar
2.0L turbocharged 4cyl 9-speed automatic
Old Nov 12, 2020 | 11:20 AM
  #173
Groucho123's Avatar
Odd...It was a software issue that you would think would be solved by the updates on a new vehicle....
Old Nov 12, 2020 | 12:56 PM
  #174
LoneStarLR's Avatar
That's a Discovery Sport, not the Discovery, they're totally unrelated beyond the name. (I *really* hate LR's naming conventions).
I don't know if the Discovery fix could apply to the Sport, but bear in mind the Sport is turbo'd, which means lag, whereas the lag issue on the Discovery is transmission related
where if you say slow down for a yield sign and before coming to a stop you hit the gas there is a significant delay before anything happens, not like the turbo lag I experienced on the Evoque I test drove which was just typical turbo engine vs transmission related.
Old Nov 12, 2020 | 07:01 PM
  #175
BritCars's Avatar
Yes - agreed. Different engine. Different gear box
I suspect you are just seeing typical turbo lag. Have you tried driving it in sport mode and does that help? Will make it kick down gears sooner and turbo is better at higher revs
Old Jan 4, 2021 | 04:13 AM
  #176
mpudlo's Avatar
7th Gear
Angry
Hello,
I'm from Europe (Poland). I have 2.0 SD4 240HP MY2017 with the same annoying issue. Service cannot help - no software patch for this engine.
Marek
Old Jan 4, 2021 | 04:16 AM
  #177
mpudlo's Avatar
7th Gear
Angry
In my 2.0 SD4 240HP engine it is not typical turbo lag. Acceleration on higher gears works perfectly. Unfortunatelly sport mode does not help.
I had oportunity to drive LR Velar with the same engine and there was no gear box issue.
Old Dec 20, 2021 | 02:11 PM
  #178
Disco5Fr's Avatar
Originally Posted by mpudlo
Hello,
Marek
Same here ...I will ask Dealer next year about a possible PCM software update
AndrewGr
May 6, 2023 03:33 PM
Hayseed_D5
Sep 4, 2018 07:28 PM
robert.juric
Jan 10, 2018 12:58 AM
Alex_M
Nov 17, 2014 07:34 AM
DanielIsr
Apr 18, 2011 01:57 PM
