My D5 build 2017 TD6 HSE Lux
Old Apr 11, 2022 | 06:03 AM
  #181
LR disco 5's Avatar
Do you have a pic of the drain plug and where it is
Old Apr 11, 2022 | 02:18 PM
  #182
gmfain's Avatar
I do not have a pic.
Once you remove the armor plating, you'll see the drain plug, and a few inches away you'll see the Tube connected, that leads back up to the top, for siphoning.
Be aware when you remove the plug, it has quiet a bit of pressure. Hold your catch container out, sorta horizontal with the drain plug.( only a few seconds, then you can sit down.)
Old Apr 11, 2022 | 03:18 PM
  #183
bkjecu94's Avatar
I think... You are supposed to replace the plug with a new one once removed. May pertain to older models?
Old Apr 11, 2022 | 05:53 PM
  #184
LR disco 5's Avatar
is it better to use the drain plug because I'm used to using those
Old Apr 11, 2022 | 06:18 PM
  #185
BritCars's Avatar
Super easy from the top. Mitivac pump or similar. Open oil filler cap. You'll see a small metal tube. Attach the mityvac to the tube and pump it out. Then pour in the new oil. 20 minute job. All from above the car. It's what the dealers do
Old Apr 12, 2022 | 06:18 AM
  #186
gmfain's Avatar
Its is better for me. I like to inspect my under side.
Everyone is different.
As far as the drain plug, If it needs to be replaced, I keep one on hand to replace it. I do not replace it with every oil change.
Old Apr 12, 2022 | 07:06 AM
  #187
LR Max's Avatar
X2 on Mitivac system. Makes oil changes a super breeze.
Drain plug is an option. Gotta drop the underside cover (I would say skid plate, but I'm not sure its stout enough for that designation). Also not too difficult.
Only issue is that used diesel engine oil is NASTY. Disposable gloves are very nice to have here.
Old Apr 13, 2022 | 06:06 PM
  #188
LR disco 5's Avatar
If you have cabin air Ionization do you have a separate cabin air filter
Old Apr 13, 2022 | 08:45 PM
  #189
gmfain's Avatar
I am not sure about that.
@ponderosajack might know that answer.
Old Apr 14, 2022 | 01:12 PM
  #190
1979rover's Avatar
Hey gmfain, what made you decide to clean your DEF injector?
I ask because I keep getting a CEL that I'm sure is regen related. Trouble is, the light will reset after a decent length drive (25-30+mins at highway speeds), but then it will come back on just a few days later. I'll do another long drive, it'll reset....then a few days later, back on.
Wondering if this could be related.
Thx.
