Rear Camera Missing Yellow Lines
Old Apr 23, 2025 | 07:59 AM
itsNate's Avatar
4th Gear
Originally Posted by jimmie86
Nope. i have the same problem as OP. U2300-56 and no tracking lines. I can select, unselect whatever i want - no lines.
Funny part is that tracking lines shows up at camera view for few seconds after ignition on.
I tried 'As built' CCF upload, checked all camera and parking aid related settings, in some cases i just lost cameras completly, but nothing helps,
Glad I’m not alone! I have yet to solve it
Have you by chance also checked fault codes? Do you have this one? IPMB-Image Processing Module 'B'
Old May 6, 2025 | 12:40 PM
jimmie86's Avatar
6th Gear
I have finally fixed mine! I spent about 500 Eur but it works. Expensive, but it took few days, and LR factory was involved, but i'm happy it works again.
Dealer said there was mistake in central database ruring move from pathfinder to topix.
this is only difference after dealer fix.
Looks like trailer assist was the issue. Try to set it as below and give feedback here.
MultiCAN-793 TA2 Input Control
Change to ATCM Rotary Switch fitted
Originally was Undefined 0x00
iidtool
iidtool
Old May 7, 2025 | 07:15 AM
Chucktastic's Avatar
That's great that you got it fixed @jimmie86 ! What year and trim is your D5? I've been looking to add the tow assist and 360 cameras that you have, but haven't figured out the full set of configuration. Would you be interested in trading configs so I can take a look?
Old May 7, 2025 | 04:16 PM
jimmie86's Avatar
6th Gear
i have l405 2018.
Old May 7, 2025 | 05:46 PM
Ah, gotcha. I think it would still be helpful to me if you're open to sharing. L405 and L462 are pretty similar from a technology perspective.
Old May 8, 2025 | 08:37 AM
tss118's Avatar
I'm not really adding anything to this, but I am new the LR fold with a 2019 Disco HSE Lux. Only has the backup camera (no surround view). I only get a single yellow line centered in the display with reverse is engaged, not the 2 lines depicting the wheel width as I am used to from other vehicles. I haven't seen a way to change this. Just and observation.
Old May 8, 2025 | 09:09 AM
jimmie86's Avatar
6th Gear
single line is tow hitch assist to help connecting trailer. in camera settings you change that.
Old May 9, 2025 | 07:43 AM
jimmie86's Avatar
6th Gear
@Chucktastic What Would you like to see?
Old May 9, 2025 | 11:56 AM
If you wouldn't mind emailing me the whole CCF from IIDControl that would be the most helpful. I can PM you my address.
stsao
Feb 6, 2025 04:00 PM
ed_rover
Jun 29, 2022 09:59 PM
Poinssixoneeight
May 24, 2021 01:09 PM
avraja
LR4
Apr 19, 2013 12:48 PM
carnut
Dec 6, 2008 04:55 AM
