Right Front Lower rear control Arm Change
Old Jan 2, 2026 | 01:33 PM
gmfain's Avatar
Default Right Front Lower rear control Arm Change
2017 D5
Tools needed: 36mm 12 point socket, 18mm 6 point socket, 1/2 air impact, air chisel with point. pry bar is helpful.
The 2 18mm bolts have LR's version of cage nuts( so they won't turn)
Spray a couple days before with penetrant lube.
45 minutes, pretty easy.
Good Luck!
Lock in lowest position, before jacking.
remove wheel/tire
remove wheel/tire
old vs new
old vs new
joint was still tight, boot split and started squeaking, no lube
Old Jan 6, 2026 | 08:26 AM
bkjecu94's Avatar
Regular wear and tear or trail damage? Thank you for sharing. kj
Old Jan 6, 2026 | 09:25 AM
gmfain's Avatar
Seems to me the rubber boot failed ( probably age), started squeaking from lack of grease.
The ball joint itself was perfectly tight, just lost its lube.
I try to inspect all the rubber during oil change time. I missed it.
Alex_M
Nov 7, 2025 11:55 PM
GrouseK9
Mar 17, 2025 10:07 AM
flyingscot
LR2
Apr 14, 2022 04:02 PM
Carlos Man
Oct 31, 2019 08:45 AM
Richard Gallant
Oct 17, 2018 10:11 AM
