Td6 after oil change - now dash pop-up says 1600 miles oil life?
Old Jul 8, 2024 | 12:43 PM
gmfain's Avatar
Originally Posted by mtaylo32
@gmfain How does your Launch CPR 909 work for you? I've run into the issue of not being able to reset the "Service due in X miles" message on the dash after countless attempts at resetting using the gas/brake reset.
@mtaylo32
Works perfect.
The gas/brake reset does not work for the 2017 TDV6, and will never work according to JLR.
I does reset it to 16K, like from factory new, but anyone with the broken crank shaft knows, we change it between 5-8k miles.
I will say this, when the computer detect to much oil dilution, and pops up to change before my 8K, I change it right away.
Hope this helps.
Old Jul 8, 2024 | 12:48 PM
mtaylo32's Avatar
Thanks for that info @gmfain ! Would you purchase the tool again or go for a different version? Yes, definitely have been sticking to the 5-8K interval since I've owned mine. Any other features you wish you had on that specific tool?
gmfain's Avatar
@mtaylo32
Amazon Amazon
Exact one I ordered.
Old Jul 8, 2024 | 12:55 PM
gmfain's Avatar
I would purchase it again.
The GAP tool will do more, but it also cost more and is your VIN specific.
I work on family member cars so, this works for me.
Old Jul 8, 2024 | 12:57 PM
mtaylo32's Avatar
@gmfain Good to know. Makes sense for my situation as well as my wife drives a Volvo. Thanks for making my mind up!
Old Jul 8, 2024 | 08:38 PM
LR disco 5's Avatar
Originally Posted by gmfain
@mtaylo32
Works perfect.
Hope this helps.
I do the 6k intervals on my D5 but I have not reset my oil light in about 30k would that cause any issues or could I just let it ride. If it's just a reminder ill let it ride I do my oil changes religiously
Old Jul 9, 2024 | 04:45 AM
gmfain's Avatar
You can let it ride. Although you will not get the early service message because of oil dilution. That said, 6K oil changes, your golden.
Rover On
Old Jul 11, 2024 | 01:24 PM
sowrco's Avatar
I'm trying to imagine a system which detects oil quality/dilution directly. I'm assuming that the ECM throws up a "change oil now" warning when it has monitored a number of factors (regens, oil quantity, trip lengths, I'm guessing) and "decided" it's time for a change. Like above mine threw out a service reminder 550 miles after I had changed the oil and reset the indicator! Talk about a false positive.
Old Jul 11, 2024 | 01:27 PM
mtaylo32's Avatar
With the warning still active on your dash does it effect drive quality? I just changed mine less than 100 miles, but still have a "850 miles to service" message on the dash. Wondering if its ok to just leave it for the time being until I get the OBDII.
Old Jul 11, 2024 | 03:11 PM
gmfain's Avatar
Thumbs up
geekinc
Nov 13, 2023 04:35 AM
SpyHop
Oct 13, 2023 09:06 AM
Eschrader
Discovery Sport
Oct 21, 2022 11:25 PM
djkronik57
Mar 17, 2017 10:28 AM
D2Owner
Dec 26, 2012 12:18 PM
