Tuning new TD6
Old May 24, 2020 | 09:30 PM
Cameron Adams's Avatar
5th Gear
Default Tuning new TD6
I currently own a 2018 LR Discovery 5 TD6. I have been looking to get a little more power out of it so I purchased a piggyback tune as it’s supposed to be extremely easy to Install and remove. My biggest concern is there is absolutely no information online in regards to anything with this motor and where each and every sensor is located and/or parts on the motor for that matter. It’s really quite disappointing to be honest as it make it nearly impossible to do any work on the vehicle confidently. I am wondering for anyone who has installed a piggyback tune, where is the dang rail sensor located? I cannot find it for the life of me and the only info online shows sensors from 2010-2012 models which has no relevance to my search inquiries. Can someone shed some insight and or send me a photo/video of the install and/or location of the darn sensor. Much thanks in advance.
Old May 26, 2020 | 07:06 PM
Black 18 Disco's Avatar
What unit did you purchase? I have printed instructions showing connection points.
Old May 26, 2020 | 07:25 PM
5th Gear
Chip express power unit. It hooks up to the fuel rail sensor
Old May 26, 2020 | 07:55 PM
ponderosajack's Avatar
please see if the attached file helps you
File Type: pdf
Old May 26, 2020 | 08:22 PM
5th Gear
this helps quite a bit. Only question is the fuel rail hidden underneath all the black plastic after you take off the engine cover? Is there more to remove to make it accessible to get to fuel rail sensor? Sorry for the questions just want to clarify and not break something that’s not meant to be taken apart. First time tinkering with a diesel. German petrol engines are much easier to work on for me.
Old May 26, 2020 | 09:19 PM
5th Gear
found it. Very easy spot but just tricky to see. Took not even 5 minutes after I finally found it. Much thanks for the diagram.
Old May 26, 2020 | 09:45 PM
Do they make a tuner for the Si6?
Old May 26, 2020 | 10:11 PM
5th Gear
chip express I believe is only for a diesel but I know racechip makes them for SI6. I was waiting for racechip for a while but they decided never to make one for the TD6 and I was losing patience so I opted for something else that would be plug and play. I don’t have the hookups for warranty related issues as I do at BMW. Therefore I don’t go crazy with performance mods as I do with my M car.
Old May 27, 2020 | 10:48 AM
Glad you found the port. I was heading to the garage to take a picture of the connector for you. I have s Chip Express also and think it is a great mod for the TD6. I had a couple earlier posts regarding performance enhancement. Best of luck with the new tune!
Old Feb 22, 2026 | 11:37 PM
Tommyb13662's Avatar
5th Gear
I'm curious how these piggyback units are as far as efficiency. Looking to improve it like my bmw x3 improved with a flash tune.
journeyman
Nov 20, 2023 04:13 PM
MoShadeTree
Jan 6, 2015 06:08 AM
gt50_90@yahoo.com
Oct 22, 2014 10:12 PM
bhorwhat
May 4, 2009 06:01 AM
smi8387
Feb 7, 2006 01:15 PM
