First Time Disco II Owner in OK..
Old Feb 15, 2012 | 09:29 PM
Kingmarine's Avatar
Default First Time Disco II Owner in OK..
Hey there, just bought a 2003 Disco II with 75k miles. It is an amazing machine. I have been reading the forums so figured I might as well join. I also have found that you can't own one of these without a lot of knowledge unless you want to pay a dealer to rake you over the coals. I have already downloaded the rave manual and am learning quickly. I currently have some leaks and a few other issues but don't think it is as bad as I initially thought about how much I would have to invest in the engine to get it current. I am getting ready to perform the 60k maintenance which I do not believe has happened. I look forward to meeting everyone and reading the forums.
Old Feb 15, 2012 | 09:50 PM
Welcome. Please be aware that your front drive shaft, if not equipped with grease fittings, and greased on a frequent basis, will split and poke a big hole in your transmission. Check out our tech section for a write up on rebuilding the front propshaft.
Old Feb 16, 2012 | 12:17 AM
Street Wolf's Avatar
Looks like you're already off to a better start than most people.
Old Feb 19, 2012 | 07:42 PM
Kingmarine's Avatar
Hey Savannah,
I have reviewed the propshaft rebuild and am wondering how important this step is at the moment if everything is functioning correctly for now? I had my brother (mechanic, but not Land Rover mechanic) take a look and he told me they were fine. I obviously do not want them to fail and am willing to rebuild them, just wondering if this should be my priority at the moment? There is no noise, pops, nothing coming from the U-joints currently. Please let me know.
Old Feb 19, 2012 | 08:47 PM
The stock ones with no grease fittings are prone to failure with little or no warning. It will take out the transmission. That's pretty expensive. Contrast that to no oil presuure - you get a warning, no coolant, you get a temperature warning. The transmission replacement is big dollars. But you'll be wanting to look at all the high miles maintenace list items, and also do a manual oil PSI test to get an idea if the oil pump is putting out the correct pressure. There is no end of things to service on a new to u Disco.
Old Feb 20, 2012 | 02:04 AM
Kingmarine's Avatar
Ok, thanks Savannah. I am putting together the parts list for the oil pressure gauge as we are in the "death" vin range and definately don't want to get into trouble there. Also planning an Ultragauge. After that I guess I'll go ahead and do the rebuild on the propshafts.
Thanks for all the help so far. It is really nice being a member of a group with so much knowledge for like interests (keeping the rover on the road).. =)
Old Feb 20, 2012 | 03:48 AM
Great - now time to move next thread to another part of the forum, so more eyeballs will see it and respond / realize they have something to do on theirs / remember a trick or two they want to pass along.
bcc
Jun 12, 2012 11:55 PM
Baylink
Dec 26, 2009 08:41 AM
ljdiscovery
May 15, 2008 09:26 AM
Skibum232
Nov 20, 2007 05:46 PM
larsenken
Sep 7, 2007 08:19 PM
