#3413
#3414
I did this a while ago but I figured I'd mention it since today I realized how much an improvement it made. A couple times in the last 6 months I've bogged down at the bottom of hills and twice I got "multiple misfires" on my ultragauge. Never got a light on the dash. The spark plugs looked ok so I kept them in and worried that it might be a fuel pump issue or something like that. Anyway, the bogging down on hills got really bad about a month ago and finally just decided to get 8 new spark plugs in there just to see if that was actually the problem. Holy crap. I had no idea how rough this thing ran. According to the tach it idled smooth but it rumbled like crazy. Figured it was just because it's a v8. With the new plugs it idles like a Prius.
Looks awesome! Do you have any issues with the tires that large?
#3415
#3416
I bought parts on eBay to upgrade the brake system on my 2001 Disco SE:
- Brake master cylinder replacement kit #SJJ100362 from Land Rover Parts and Accesories ($70)
- EBC GD Sport Drilled & Slotted Rear Rotors #GD957 from Sakarl Motorsports ($155) pair
- EBC GD Sport Drilled & Slotted Front Rotors #GD994 from Sakari Motorsports ($185) pair
- Akebono ceramic rear brake pads #ACT493 from Volksgene ($40.44) for 2 sets
- Akebono ceramic front brake pads #EUR676 from Aims Autoparts ($71.65) for 2 sets
- Braided Stainless Steel Brake Hose Kit for raised suspensions #ABP218L from Atlantic British LTD ($157.95)
- Stainless steel brake bleed ports #SB1010S-SS from Speed Bleeder ($65.95) 4 each
- Pentosin Super Dot 4 brake fluid #BFDOT4-L from Pep Boys ($11.19) x 3 liter cans.
#3419
#3420
Replaced the water pump, viscous fan and serp belt as preventative maintenance today.
also backflushed the coolant system and replaced the dexcool for prestone green coolant.
after a quick drive im noticing lower running temps at 40 to 50mph, but slightly higher at idle. Still in the 186 to 194f range, but need to bleed some air out over the next couple of days
