Old Jul 21, 2017 | 08:17 PM
  #4241
MacRoadie's Avatar
Default Cargo Shelf
Added a shelf, a slider, an inverter, and some LED lighting to the cargo area.
Old Jul 21, 2017 | 08:20 PM
  #4242
Swapped out the number 6 plug wire and determined it's the coil pack. Now trying to find a good deal on some new Bosch coil packs
Old Jul 21, 2017 | 08:26 PM
  #4243
aemnky606's Avatar
What size is that inverter? How did you wire it, and what size wire did you use?
Old Jul 21, 2017 | 08:31 PM
  #4244
MacRoadie's Avatar
1500W. I ran a new dedicated hot and ground directly from the battery and up through the cargo space floor. Used #4 battery wires (aka welding cable).
Old Jul 21, 2017 | 10:42 PM
  #4245
looks sharp man
Old Jul 22, 2017 | 08:47 AM
  #4246
SensiRider's Avatar
Originally Posted by mln01
So now grease them!
When you grease them (this weekend, right?) don't just pump the grease gun a couple of times. Keep pumping until FRESH grease exits each of the four U-joint bearing caps. Wear nitrile gloves and wipe off as much of the excess as you can. Done forget to also grease the shaft splines. And don't forget the rear shaft.
Let us know any questions you may have.
Specific grease recommendations?
Old Jul 22, 2017 | 08:53 AM
  #4247
I did the inline thermostat mod.....finally!!!!
Old Jul 22, 2017 | 02:53 PM
  #4248
dtmbinb's Avatar
I replaced my driver's door window regulator and motor in between thunderstorms. Good times. Lol.
Old Jul 22, 2017 | 04:49 PM
  #4249
Friday Night Disco's Avatar
new heater core installed, bleeding the system now and checking for leaks.
I will post up in my tricky dick thread on how I installed mine in case anyone is interested.
Old Jul 22, 2017 | 06:18 PM
  #4250
I hit up a couple of Pull-A-Part businesses in the Atlanta area and scored for $72 Disco and Audi A6 parts:
- 2 pairs of D1 windshield wipers
- D2 air filter cover without broken latches
- 4 roof gutter corners
- 2 A-pillar trims
- driver's side rubber LR mat
