03/04 trans vs 02 trans, difference?
Old 04-27-2014, 02:09 AM
abran's Avatar
Default 03/04 trans vs 02 trans, difference?
Can anybody tell me the difference between the 03/04 trans and the prior versions?
Are there fitment issues or just performance? Your savoir faire is appreciated.
Thanks
Old 04-27-2014, 02:36 AM
Dane!'s Avatar
I think they are all the ZF 4 speed autos, and nothing has changed about them through the D2 years, I could be wrong though.
Old 04-27-2014, 06:18 AM
Paul Grant's Avatar
The '99-'02 DII uses the ZF 4HP22 trans mission whereas the '03-'04 models employ the 4HP24 transmission. The change was made to the 24 to accommodate the 4.6 increase in power. This occurred in the GEMS P38a as well and naturally continued right through '02.
The transmission found in DI's, while ZF 4HP22's, are not compatible with those found in DII's because of the change from mechanical to electronic management.
I have never seen a transmission from a P38a, whether it be GEMS or Bosch, successfully repurposed for a DII.
Old 04-27-2014, 06:22 AM
Paul Grant's Avatar
I guess I should have also mentioned that the 4HP24 and the 4HP22 are not exactly the same in terms of dimensions. This is why the '03-'04's have front driveshafts with a slightly different length than those found on earlier DII's.
Old 04-27-2014, 06:59 AM
abran's Avatar
Thanks Paul! You are a wealth of knowledge.
The People Family
08-06-2008 10:32 PM
woodsrider
12-11-2006 07:54 PM
IH1973
08-04-2006 11:00 AM
rirover
07-07-2006 07:22 PM
roverATH45
06-05-2006 09:56 AM
Quick Reply: 03/04 trans vs 02 trans, difference?
