03/04 trans vs 02 trans, difference?
Can anybody tell me the difference between the 03/04 trans and the prior versions?
Are there fitment issues or just performance? Your savoir faire is appreciated.
Thanks
Thanks
The '99-'02 DII uses the ZF 4HP22 trans mission whereas the '03-'04 models employ the 4HP24 transmission. The change was made to the 24 to accommodate the 4.6 increase in power. This occurred in the GEMS P38a as well and naturally continued right through '02.
The transmission found in DI's, while ZF 4HP22's, are not compatible with those found in DII's because of the change from mechanical to electronic management.
I have never seen a transmission from a P38a, whether it be GEMS or Bosch, successfully repurposed for a DII.
I guess I should have also mentioned that the 4HP24 and the 4HP22 are not exactly the same in terms of dimensions. This is why the '03-'04's have front driveshafts with a slightly different length than those found on earlier DII's.
The People Family
Aug 6, 2008 10:32 PM
F451_Guy
Dec 11, 2006 07:54 PM
rirover
Jul 7, 2006 07:22 PM
roverATH45
Jun 5, 2006 09:56 AM
