abs fix
Old 11-10-2014, 04:10 AM
scarpinatore's Avatar
6th Gear
Default abs fix
Hi all,
I uploaded the three pdf files with all the images.
Disclaimer: The files have been produced by maui27 of the africaland.it forum, thanks to him for the effort and sharing!
File Type: pdf
File Type: pdf
File Type: pdf
The following 9 users liked this post by scarpinatore:
acg (02-09-2015), danboy (02-10-2015), Fuddy (11-13-2014), GetOverRover (03-03-2015), Jon Wright (09-20-2017), JUKE179r (05-07-2018), My6speedz (01-29-2015), san988 (12-02-2014), The_OGCJR (02-18-2023) and 4 others liked this post. (Show less...)
Old 02-07-2015, 09:28 PM
dusty1's Avatar
another useful one
Disco ABS Fault
The following 4 users liked this post by dusty1:
acg (02-09-2015), danboy (02-10-2015), JUKE179r (05-07-2018), psg (02-07-2015)
Old 02-09-2015, 08:16 PM
dusty1's Avatar
Default abs fix
most of the original is gone, but a couple of guys put up some decent info.
figured it would be helpful to put the good stuff here and not have to look through the dead links
newly addressed thanks to Josh
http://landroverclubvi.weebly.com/
The following 2 users liked this post by dusty1:
psg (02-09-2015), Virgil Grillone (06-29-2022)
Old 01-22-2019, 11:27 PM
Sito's Avatar
Thanks for such a good job. I have a doubt, the lights disappear but the traction control is still in operation and it helps the descent?
Thank you.
RBS (04-19-2020)
Old 04-06-2020, 06:21 AM
RoverSE7's Avatar
does bypassing the shuttle valve make the ABS system in operative?
Old 04-06-2020, 06:45 AM
ahab's Avatar
You're not bypassing the shuttle valve. You're renewing a source of ground which enables the switches inside the shuttle valve to function correctly. ABS is not in any way compromised.
Old 04-06-2020, 07:06 AM
mln01's Avatar
No, as ahab said this fix restores full ABS operation. It bypasses a faulty printed circuit board in the ABS module; it does not bypass the ABS system.
Be sure to do Option B. There is no need to disconnect any of the brake lines. Please ask if you have any more questions.
Old 04-06-2020, 07:45 AM
RoverSE7's Avatar
Thanks guys you are invaluable !!!
Apestit
09-11-2017 07:11 PM
countryman
01-21-2017 02:18 PM
Stephen Disco 2
12-16-2015 11:42 AM
30more
11-12-2015 11:10 AM
drakenkade
12-19-2010 01:28 AM
Quick Reply: abs fix
