Go Back   Land Rover Forums - Land Rover Enthusiast Forum > Vehicle Line Up > Range Rover
Register Forgot Password?
Old 12-02-2011, 08:40 PM
Junior Member
Default Stuck in Neutral
So ive got an 05 RR and it is stuck in neutral. On the dash it says transfer box neutral and is in low range. It won't go into high range and nothing happens when I slide it thru the gears. I want to be certain befor I work on it. I was thinking it is te transfer case shift motor and possibly the h/l range motor. I've already made sure fuse 37 is out.
Anyone know what it could be?
Old 12-02-2011, 09:34 PM
Senior Member
I think your idea about shift motor or switch that is part of it is spot on.
__________________
Old 12-03-2011, 05:20 PM
Senior Member
did you get the recall front diff done, and its possible the front axles slipped out and caused the issue as well.
__________________
"If you think it's expensive to hire a professional to do the job, wait until you hire an amateur." Red Adair
Land Rover technician Got a problem just ask. If you are a fellow LR tech then I would like to hear from you.
Old 12-04-2011, 01:40 AM
Junior Member
I'll give the dealer a call on the dif Monday I just got the vehicle from an auction. Is there any way I can testit to see if the motor is bad before taking it off?
Old 12-06-2011, 07:44 AM
Senior Member
I wouldn't bother until you get the vehicle diagnosed.
transfer neutral can be anything.
Wait did you drive the vehicle from the auction or tow it? If you towed it, they may have installed the fuse.
__________________
Tags
05, box, case, hse, land, motor, neutral, nuetral, range, ranger, rover, shift, stuck, transfer, transferbox
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
Emails Backup
