Stuck in Neutral
Old Dec 2, 2011 | 08:40 PM
cbarnett23's Avatar
4th Gear
Default Stuck in Neutral
So ive got an 05 RR and it is stuck in neutral. On the dash it says transfer box neutral and is in low range. It won't go into high range and nothing happens when I slide it thru the gears. I want to be certain befor I work on it. I was thinking it is te transfer case shift motor and possibly the h/l range motor. I've already made sure fuse 37 is out.
Anyone know what it could be?
Old Dec 2, 2011 | 09:34 PM
I think your idea about shift motor or switch that is part of it is spot on.
Old Dec 3, 2011 | 05:20 PM
Rovin4life's Avatar
did you get the recall front diff done, and its possible the front axles slipped out and caused the issue as well.
Old Dec 4, 2011 | 01:40 AM
cbarnett23's Avatar
4th Gear
I'll give the dealer a call on the dif Monday I just got the vehicle from an auction. Is there any way I can testit to see if the motor is bad before taking it off?
Old Dec 6, 2011 | 07:44 AM
Rovin4life's Avatar
I wouldn't bother until you get the vehicle diagnosed.
transfer neutral can be anything.
Wait did you drive the vehicle from the auction or tow it? If you towed it, they may have installed the fuse.
ImQuattro
May 1, 2014 08:36 PM
bobmaucher
Apr 24, 2012 07:18 AM
cardinal77
Nov 24, 2011 05:52 AM
discoduck17
Jul 21, 2011 02:18 PM
97DISCOIDAHO
Apr 13, 2007 11:09 PM
