1 year Service
Old Nov 1, 2024 | 01:47 PM
  #101
GCSchmidt's Avatar
@GavinC
Found the specs...they are a little different...Below are the spark plug specs for the P400 from the Service Manual: Section 303-07C Engine Ignition
Downloadable PDF here: https://landroverforums.com/forum/20...0-p400-109129/
Spark Plug Part #: LR178881 (Supersession: LR091617)
Spark Plug Gap: 0.6 - 0.65mm
Spark Plug Torque: 23 Nm (17 lb-ft)
Ignition Coil Bolts Torque: 8 Nm (5.9 lb-ft)
Old Nov 1, 2024 | 05:55 PM
  #102
GavinC's Avatar
Originally Posted by GCSchmidt
@GavinC
I did had to gap the new plugs myself and used the Lang 4450A Spark Plug Ramp Gauge to set the gap...they were way off and not consistent between them.
I am not sure of the gap specs for the 3.0 I6. I'll look through the service manual and see if I can find them.
Downloadable PDF of Service Manual can be found here for both engines (P300 & P400):
Ended up using two socket universal joints and extensions between them to get to the plug near the firewall.
Thanks again
Yeah I was able to get the specs from the manual. I have it downloaded some years back. Useful to have for sure. The gap spec is in there. I have a gapping tool and gauge so shouldn't be too much of a hassle. We'll see.
Old Nov 3, 2024 | 09:39 PM
  #103
GavinC's Avatar
An update on GAP setting for the inline 6 P400 Ingenium.
The plugs are Iridium centered and supposedly come with the correct gap setting. Being Iridium, they apparently should not be gapped, but can have their gap verified to be correct. This was news to me. Last spark plugs I did were on a 1982 Datsun Bluebird so I'm not exactly clued in.
All 6 of were verified to be gapped correctly.
Changing the plugs involves among other things.
  • Removing the low pressure air duct from the top.
  • Removing a center bulkhead panel between engine and firewall
  • Moving aside some air suspension hoses
  • Removing the cross-member above the engine (11 M8 bolts)
  • Putting the air distribution doohickey into service mode. (removing oodles of bolts and connectors to do this)
  • Lifting the hood all the way up, removing the struts to allow this.
Should be quite the adventure. 4 beer task minimum
I'd love to know what a dealership would charge for this service item. Probably not as complicated as it sounds in the manual. I guess the I6 just runs out of room for a simple change of plugs.
Old Nov 6, 2024 | 07:20 AM
  #104
GrouseK9's Avatar
@GavinC - And THAT is why I'm now glad my Defender sits on the east coast closer to Sarek... I've been much more open to having someone else do some service work for me as I get older! But, as mentioned - it ultimately depends on the cost.
Old Nov 7, 2024 | 03:57 PM
  #105
GavinC's Avatar
You've left the warm embrace of Texas' sage in bloom and wide and high prairie sky for the East coast? Sorry for your loss.
Old Nov 16, 2024 | 08:57 PM
  #106
GavinC's Avatar
As tasks go, this is as simple as you’d like
I am glad to have done this change earlier than the 63000 prescribed mileage
very dark thick diff oil
Sludgy black diff oil
This is the fill plug
Metal shavings are minimal.
Gap tool and Trax getvyoubplentybof room to work
Gap tool and Trax get you plenty of room to work
Next up is the transfer case.
Old Nov 22, 2024 | 08:51 PM
  #107
GavinC's Avatar
Default Transfer Case Oil Change L663
51,700 miles
Scheduled maintenance has this due at 63,000 miles.
  • Lift the front end and chock the rear wheels
  • Pop off the undershield
  • Partially remove the left underfelt
  • Remove Fill plug
  • Remove Drain Plug
  • Drain transfer case
  • Replace crush washer and tighten drain plug to 28Nm (21 ft lb)
  • Fill transfer case with correct fluid. I used OEM
  • Replace crush washer and tighten fill plug to 28Nm (21 ft lb)
  • Reinstall felt
  • Reinstall undershield.
OEM fluid. Incorrect size crush washers from Landleaping.com Reused the old ones, much to my chagrin.
Hex socket on drain and fill plugs
Transfer case
Transfer case
Lift and jack stands as a fail safe.
A new beverage for a new task.
Optional. Spend an hour struggling with the undershield bolts like a moron. Hacksaw off a stripped bolt and add sailor-talk to taste
Crack a cold one
Test drive.
Bourbon.
Old Nov 23, 2024 | 04:10 AM
  #108
Defendit..'s Avatar
@GavinC
Nice job, how did the oil look ?
Old Nov 23, 2024 | 05:37 AM
  #109
lightning's Avatar
How much oil was needed. l assume you didn't replace the oil in the gearbox as that's not an easy task!
Old Nov 23, 2024 | 11:10 AM
  #110
GavinC's Avatar
I didn't measure exactly. I just filled it till it reached the fill hole. Volume used was comparable to the capacity in the manual (1.25L) plus a little spillage.
I didn't do the transmission fluid yet. I'm probably still a bit early mileage to be doing that one. I'd have to check the manual for the scheduled miles but I think it may be at the 105k service. I'll not go that long.
Spark plugs next.
