2023 Models without Softclose Door and Fan Control ?
#81
The following 3 users liked this post by Trekkie:
#83
Revisiting this retrofit for 2023 models, does anyone know where to buy the (3) x rubber grommets (part # ?) and the appropriate wiring harnesses to plug and play?
The motor can be had by most US LR Dealers for ~$200 USD (vs. 400+ GBP on the retro fit "kits" from third parties).
#84
Not only you need the motor, you also need a new lock for this retrofit.
I bought mine from Hunters Prestige and they also have a fitting video. Very handy. Soft close works perfectly.
https://huntersprestige.com/collecti...lgate-retrofit
ficklma1 (09-04-2023)
#85
#86
#87
It's a little bit more complicated than just adding the motor, Vulkan in the UK are supplying a kit to enable you to fit it
https://youtu.be/erbwBUZfQYQ
#88
Sir, can you share which MY Defenders (and trim levels if applicable) HAVE the soft-close feature? I am looking at several Certified Pre-Owned Defenders to include both 2021 and 2023 MYs. Thank you much
