Headlight failure (led ring/DRL)
Old Apr 24, 2026 | 02:28 PM
  #191
cbell2112's Avatar
So what controls the turn signal? I've watched several of the videos on doing this myself. I am just not confident that I can get the headlamp assembly pulled apart and glued back together properly.
Old Apr 24, 2026 | 03:07 PM
  #192
GavinC's Avatar
Some other electrical doohickey that's not badly designed. Turn signal is completely unaffected by the DRL failure. The two squares still light up initially but will go out as they need some electrical handshake from the halo to stay on. These are otherwise unaffected and will work normally when you swap in the DRL module.
I didn't fancy my chances either so just got a direct replacement from a breakers yard for less than $380 and got the replacement DRL module for $2.38
Now I have a spare headlight.
You can buy failed DRL light assembly on ebay for about $50-$75. The DRL modules themselves are dirt cheap. Even if you do break some of the plastic in th eheadlight surround it doesn't matter. It all gets hidden when the light goes back in place. I did mine just for fun really. I think with practice this could become routine.
Old Apr 24, 2026 | 04:11 PM
  #193
cbell2112's Avatar
Do you think there is any chance the turn signal will start working if I program the DRL's to remain off with the GAAP tool? Doesn't sound like it.
Old Apr 24, 2026 | 04:57 PM
  #194
GavinC's Avatar
Completely unrelated. The turn signal will be unchanged. You’ve been given bad information. Easy to fact check this. Just turn them off with GAP and you’ll see all is well.
the DRL halo snafu has no impact on indicators. None.
Old Apr 30, 2026 | 07:59 PM
  #195
Elektrapops's Avatar
Thought I'd add this: My LH DRL failed last year and was replaced free under the 4-year warranty. And as expected, my RH DRL has just failed, which is 6 months beyond my warranty. My dealer has been excellent and has just emailed that JLR would cover 60% of the replacement (my cost is a little over $1k).
So it's nowhere near as bad as I was expecting. However, it does signify to me that perhaps this DRL failure will end up as a Recall.
Old May 1, 2026 | 07:40 AM
  #196
cbell2112's Avatar
Thanks, we are pursuing this option now as well.
Steven Niketas
Range Rover L405 (Fourth Gen)
Aug 15, 2022 09:30 AM
09dewaed
Dec 4, 2017 06:36 PM
snugg
Dec 16, 2008 10:03 PM
Disco03
Dec 1, 2008 08:08 PM
Street Wolf
Oct 3, 2008 08:40 AM
