No Lift tire size guide (work in progress)
Old May 13, 2024 | 05:06 PM
  #581
JBelt01's Avatar
Originally Posted by Huc
As of the new release this month (see attached and this link ), BFG KO3's are still NOT offered in 19". There is supposed to be another release or two in 2025 and wrapping up new release in 2026. I've looked pretty hard but have not seen any indication for sizes other that's what's offered thus far.
I'm currently getting ready to swap out for either BFG KO3 or Falkan A/T4W at LT265/70R18 load range E, along with the Lucky8 Caliper kit as I can't bare to grind those luscious red brake calipers on my 110x LOL If anyone can confirm that tire size fits w/out rubbing at full turn at Access - Normal - Off Road ride heights I'd appreciate it. Research here and elsewhere thus far says I should be okay.
Your OE calipers (or Discovery take-offs) are likely better quality than whatever Lucky 8 is sourcing, and would allow a dealer to service them with JLR parts.
Old May 14, 2024 | 06:06 AM
  #582
NoGaBiker's Avatar
Correct me if I’m wrong, but I believe LK8 sources Disco calipers (new, not takeoffs.) I just got the correct part numbers and ordered from my dealer, but that was my understanding in 2022 at least, when I did the swap.
Old May 14, 2024 | 11:03 AM
  #583
curb-optional's Avatar
There are zero reasons to run an odd ball 19” wheel. No idea why JLR even offered it. Replace with 18s or 20s if you plan on keeping the car.
I'd really just need a few options. Right now, the Goodyear Duratrac and the All Terrain with Kevlar both look excellent? But I've not driven with them yet. I don't need alot of choices - just something. For mostly highway driving Scorpion and Continental have one offering each, but I think I will stick with the Goodyear tires.
Old May 14, 2024 | 11:19 AM
  #584
Mike_F's Avatar
I'm still using the stock Goodyear Adventures on 18" steelies (P300). They're surprisingly better than I feared. I decided just to use them until they needed replacement, rather than spend the $ to replace brand new tires.
I've taken them on challenging offroad trails in central Pennsylvania; rocky ups and down, one of which is a Jeep badge of honor trail where I tagged along behind Rubicons. I aired down to 18 psi and never had an issue. Where I struggled, it was because of my limited ground clearance compared to the Jeeps, not because of my tires.
That's rocky trails. I haven't taken them in real mud, or Moab slickrock, so I can't speak to their performance in those environments. I also haven't had a rock try to slice a sidewall, so maybe I'm just lucky there - the KO3s would certainly be a better bet if your sidewalls are at risk.
But I have no regrets using up the stock AT tires. Having said that, I'll probably get something more aggressive when it's time to replace them.
Old May 14, 2024 | 11:29 AM
  #585
TheAkita's Avatar
Need some advice - I want to get some Rotiform STL wheels to serve as my winter/off road setup. I have a '23 D90 with the stock Brembo calipers and 22" rims. Tire Rack says the 20x9 rims with +30mm offset should work for me. First, I just wanted to confirm that those rims will be able to fit around the Brembo calipers. Second, I was hoping for some tire recommendations. I absolutely cannot lift my Defender because I have the expedition roof rack and I just barely fit into the parking garage at my work on the lowest suspension setting. All the tires that TireRack is recommending are 255/60R20. Does that imply that any tires that I want will fit with the Rotiform rims as long as they are that size? Thanks!
Old May 14, 2024 | 02:26 PM
  #586
Zondar's Avatar
I'm getting ready to take delivery of a 90S on 18" steel wheels / springs with the OE AT's.
I don't feel the stock AT's would be very trustworthy on the western US trails I've been on (nothing but rocks like daggers just waiting to slash your sidewalls). Therefore, I'm considering swapping for BFG KO3 in 265 / 70 R18. From wading through this thread, it seems this should be OK. Again, I'll be on springs, not air.
Confirmations / cautions about fitment? Consider Wildpeaks instead? Would those be significantly quieter?
What sort of accommodation might be hoped for from the dealer if asked to do a swap upon delivery?
Thank you.
Old May 22, 2024 | 11:34 AM
  #587
Ratledge's Avatar
Default Falken Wildpeak A/T Trail in 255/60R19
I am trying out the Falken Wildpeaks in a 60 series tire. Yes, I am losing 1/2" of sidewall and of course it's 31.3" instead of 32.1" diameter.
Unlike the OEM Goodyear 255/65 tire, these stick to the road like glue. Not in a bad way, we're talking better traction all-around.
That's not why I switched, I wanted better winter / snow handling, and the OEM tire isn't all that good as far as hydroplaning. Those two aspects will be waiting for weather, but these are a real step up for handling and traction!
I was waiting for the KO3 tires, originally KO2 and those look like 18 months out vice six. I lost two of the Wrangler tires on rocks driven square into the center of the tread. The OEM tires are 6 ply, 2 sidewall, 4 tread. The non OEM ones are 10 ply, addng 2 in both sidewall and tread. The second loss to a rock was a 10-ply tire...
Old Jul 3, 2024 | 10:03 AM
  #588
D110Xd's Avatar
Originally Posted by Ronin Defender
305/50/20 BFG no lift no rub..
I seriously love the way these tires look. I want to order them so badly, but I'm afraid with my luck I will have rubbing issues. I know you said no rub with and without spacers. If it isn't too much trouble, is it possible to maybe take a photo of how close it is to the inner liner at full lock or maybe how close to the upper control arm in access mode?
Old Jul 3, 2024 | 11:45 AM
  #589
Ronin Defender's Avatar
Dude why would I lie since I have two sets of wheels with these tires mounted..
Don't do it I would rather be the only non sheep here..
Old Jul 3, 2024 | 11:50 AM
  #590
D110Xd's Avatar
Not saying you're lying at all. I'm just really surprised more people haven't gone for this size tire.
