Trickle Charger: Yes, No?
Old Apr 16, 2024 | 07:16 AM
  #51
longtrip68's Avatar
Originally Posted by GrouseK9
LOVE THIS!!! Just charged my Defender yesterday.
What post are you referring too when you say you “LOVE THIS”? Please share, as maybe I will love it too
Old May 24, 2024 | 02:56 PM
  #52
HMBodo08's Avatar
Hey all. Figured I would share my set up after some help from @Dogpilot . My dealership was cool enough to install my leads to the terminals while i was in for service so that saved me some time but after I did the cosmetic placement of the quick connector from Ctek when I got home. Below are some pictures during that process. I will use some type of adhesive sealer to clean it up a bit and make it more secure but the template that came with the quick connect really helped make a perfect hole for it to lock in.
Old May 24, 2024 | 03:59 PM
  #53
longtrip68's Avatar
Originally Posted by HMBodo08
What is this little thing? Is this where you connect to the charger? Is it mounted there, or just loose? Thanks
Old May 24, 2024 | 04:03 PM
  #54
HMBodo08's Avatar
That is the quick connect box that is hard wired to the car. Then you just plug and charge at anytime. Yes it is mounted there but you can mount it anywhere you want.
Old May 24, 2024 | 04:45 PM
  #55
Norsk's Avatar
Bingo! Thanks for this.
Old Jun 17, 2024 | 07:49 AM
  #56
sblvro's Avatar
Just connected my 110X to a tender as it will not be used for two months. I have other vehicles to daily. Wow it took a day and a half to fully charge the battery. FYI, I have a blackvue 970X 2 channel that probably would drain the battery to 12.3 Volts before turning off parking mode.
Hovdebo
Nov 19, 2024 06:11 PM
Windycity_rover
May 4, 2023 08:36 PM
Shahi92
Apr 29, 2022 04:50 AM
OBieSr
Defender
Mar 22, 2022 02:27 AM
ebarry
Dec 20, 2020 12:25 PM
