4.6 engine build
Old Mar 24, 2015 | 02:08 PM
  #61
drowssap's Avatar
At least your not using tub & tile chauk like the last time
Originally Posted by dusty1
Uh, right stuff has white.
Old Mar 24, 2015 | 02:18 PM
  #62
dusty1's Avatar
Well This stuff is white. Maybe a good replacement for that little flat gasket thing, between the head and block
Old Mar 25, 2015 | 09:07 AM
  #63
dusty1's Avatar
dropped in the rhoads bleed down lifters. interested to know if these actually do anything.
5/16 chrome molly push rods. I had to clearance the passage a bit.
installed my yella terra roller rocker assemblies. this I am excited about because less friction always makes more power. still have to adjust them
so to sum up to this point, I will highlight the (hopefully) performance upgrades.
top hats- no performance there, just reliability
crower cam 53231. direct from crower
crower 68405 dual springs
heads port and polish
slightly over size valves. 41.4 int./35.5 ex. (these are a sbc standard size)
hd push rods
bleed down lifters
roller rockers
almost there. anyone want to set the over/under for horsepower gains? I better see something
Attached Thumbnails 4.6 engine build-dsc_6704.jpg   4.6 engine build-dsc_6705.jpg   4.6 engine build-dsc_6706.jpg   4.6 engine build-dsc_6707.jpg   4.6 engine build-dsc_6708.jpg
Old Mar 25, 2015 | 09:22 AM
  #64
drowssap's Avatar
rhoads anti pump-up lifter are usually use with a somewhat radical cam, so you can don't have to worry about valve-train float they are help you maintain vacuum need for accessory.
But the last set i put in was in HS in 1977 they may have change since then, btw those lifters are still in an engine being used now.
I see you went with roller rockers why? doesnt the ECU have like a 5800 rev limiter? or was it just for noise?
Old Mar 25, 2015 | 09:29 AM
  #65
dusty1's Avatar
Noise and friction reduction on rockers. Friction reduction being the main goal.
Old Mar 25, 2015 | 09:52 AM
  #66
Shiftonthefly1's Avatar
I have rod envy.
You gonna do a parts list when your done or is it like a secret recipe? I thought you were going to eliminate the rocker shafts?
Old Mar 25, 2015 | 10:03 AM
  #67
dusty1's Avatar
Originally Posted by Shiftonthefly1
I have rod envy.
yes i will do a complete price and part list.
i originally planned to do stud mounts, but after research i had a change of heart. the stud mounting allows for the use of any sbc roller rocker and is super cheap in comparison to the yella terra.
my problem was with the oiling through the push rod. while it is a great technique and very efficient..... with the spring rates and changes, i wanted the strength of a solid push rod more. so I coughed up the cash for the only shaft mount roller rockers that are made for these.
Old Mar 25, 2015 | 01:24 PM
  #68
dusty1's Avatar
I have rod envy.
here are a few numbers for you.
really the only thing i haven't had to pay for yet is fueling changes.....if i do any
i added some essential pricing of misc. junk required.
Crower cam 53231 $267.87
Crower tungsten alloy dual springs 68405 $124.06
Crower chromoly retainers 87021 $67.04
hd pushrods 603378hd $85.12
Rhoads lifters 9698x $188.00
Yella terra roller rockers yt6000r $818.58
Inlet valve 41.4mm rb74680 $83.92
Ex valves 35.5mm rb7461 $99.20
After a cross reference I purchased sbc valves. The numbers above are rimmer bros part # and are the same thing at nearly the exact same price… they already did all the work…live and learn
Glyco big end bearings $35.01
Glycol main bearings $68.04
Timing chain with sprockets $101.17
Oil pump gear with gaskets and front main $119.95
Main cap and cross with washers and big end bolts $89.95
Some chose to reuse
Rear main $16.95
Arp head studs $201.14
Head gasket set $137.46
Hedman hedders 39800 $219.97
I had them coated, but it was iou payment
Old Mar 25, 2015 | 01:30 PM
  #69
Anything you'd change or do differently ? Do you really feel the 800 bucks for the rockers are worth any gains?
Old Mar 25, 2015 | 01:47 PM
  #70
dusty1's Avatar
i wish i had done a 5.2 crank and double timing chain. chain set was out of stock and i didn't want to bend over for $omeones bigger crank so i made this a 4.6 build.
i really wanted to reduce friction as it is a hp eater. that price does seem crazy, but i started this process with the mind set of "doing everything i could to squeeze more power outta this 4.6". i wish i felt more comfortable with the hollow oiling and stud mounts. that would have been under $300. also, i have dumped some other hp parasites. I have electric fan and water pump.
actually none of this may be "worth" it. it all depends on the gain. the bottom line is definitely worth it considering i will have a complete spare/additional 4.6 engine, at around 5k. of course, this is only true if it actually works and works well.....i will be singing a different tune if i have a rod sticking out the hood, next month.
