4.6 engine build
Old Mar 26, 2015 | 10:41 PM
  #81
dusty1's Avatar
Default throttle body heater ......my solution!
so i have a 1/8 " copper line, fitted to the heater. it goes through the input / output. then i have soldered some small 1/4 pieces on. now i can double clamp the tbh and new 1/4". this excludes the gasket and tbh, all together......but still produces heat for the throttle body..
Attached Thumbnails 4.6 engine build-dsc_6770.jpg   4.6 engine build-dsc_6771.jpg   4.6 engine build-dsc_6772.jpg   4.6 engine build-dsc_6773.jpg
Old Mar 26, 2015 | 10:47 PM
  #82
dusty1's Avatar
had to use spacers for the rockers.
Attached Thumbnails 4.6 engine build-dsc_6775.jpg   4.6 engine build-dsc_6776.jpg   4.6 engine build-dsc_6778.jpg   4.6 engine build-dsc_6780.jpg
Old Mar 27, 2015 | 06:13 AM
  #83
drowssap's Avatar
get closer,
I had a lot of problem with the TBH until i dress the bottom with a file, so far so good.
Old Mar 27, 2015 | 09:30 AM
  #84
dusty1's Avatar
also should have mentioned that i purchased spacers and rockers from v8tuner. (good folks, very helpful)....they supplied longer valve cover bolts. they are stainless and i now get to use a 3/16 hex to tighten.
for standard size they also had an option of a thumb screw.
Old Mar 27, 2015 | 10:31 AM
  #85
drowssap's Avatar
they also sell them tapped for ford and chevy, in case you putting a rover in your kit car.
Old Mar 27, 2015 | 10:36 AM
  #86
dusty1's Avatar
Default plugs and wires...
went with some gimmicky looking e3 plugs......dunno maybe they are good....anyone?
and i got 10mm wires from summit. figured 10 is better than 8 for heat.. it is worth a go @$109
Old Mar 27, 2015 | 11:08 AM
  #87
drowssap's Avatar
i have E3 in the p-38 no problems, the truck actually likes them
Old Mar 27, 2015 | 11:12 AM
  #88
Shiftonthefly1's Avatar
Oh great. Twice the chance of a valve cover gasket leak.
10mm wires??! I had no idea they existed. That's 'Merica right there.
Old Mar 27, 2015 | 11:27 AM
  #89
dusty1's Avatar
yeah. the wires are huge. i had to buy some fleabay separators, as there is no chance of using stock. the wires are dui/davis. i have used their wires before and have had great luck. got them a summit
if you look at the valve cover finished, it looks like a brick mason set them with $9 worth of rtv........
so, they will not leak. i just hope i don't need to adjust the rockers after i get it going
Old Mar 27, 2015 | 11:28 AM
  #90
dusty1's Avatar
that is promising. thanks. the reviews were great and i can always get some champs at lps
