Cruise issue
Old Sep 14, 2010 | 09:22 PM
I must have cruise, I have a heavy foot and without it I would be doing 90+.
Old Sep 22, 2010 | 12:47 AM
LR32955's Avatar
1 of my rubber hoses are gone, anyone have a diagram of where they go ?
Old Sep 22, 2010 | 07:47 AM
okdiscoguy's Avatar
One goes to the control box under the jack in the front driver's side. It goes back to a t-fitting where one line goes to the throttle bladder and one goes through the firewall to a brake switch. It does not run off of engine vacuum. The control unit has its own pump.
Old Sep 22, 2010 | 09:14 AM
Rover Chris's Avatar
oh how life was so much nicer when a cruise control issue was the most of my worries!
Old Sep 22, 2010 | 11:17 AM
jigray3's Avatar
I have spent countless hours trying to get my cruise back up multiple times over the years, and have sniped off split vacuum lines at T-fittings many times. Cruise has been a priority for me because the driving position cramps my right ankle badly on trips. I beileve that, much like the rubber gaskets around the rear quarter and rear door windows, the rubber for the OEM vacuum hose used in the CC is prone to dry rot. Replacing the line with generic auto parts store vacuum line will likely result in a more robust less trouble prone system because the hose is simply better. That said, I agree with Spike that nothing wrong with a quick fix that is easily undone later if need be. All the more so if you don't have to spend a lot of time and effort routing the replacement hose.
Old Sep 22, 2010 | 02:43 PM
DiscoJag's Avatar
Default CC
Mine did the exact same thing and the reason I just cut the hose above the split and re-used it is I didn't want to have to route one through the firewall down to the brake mechanism. Maybe if it splits and quits again... but it's workin' for now. Sometimes the lazy man's way works fine.
Benhamtroll
Jan 18, 2009 08:01 PM
Prepilot_3ck
Jul 2, 2007 11:41 AM
Brad S1
May 8, 2007 12:57 AM
slangel
Oct 7, 2006 11:55 PM
madas
Aug 27, 2006 04:54 PM
