Disco I Replacement Radiator
Old Feb 12, 2020 | 02:13 PM
  #31
Best4x4's Avatar
Yep also the stupid aluminum upper radiator supports are mounted WAY back so if you used em the PS reservoir is kissing the airbox latch/lid.
Old Feb 12, 2020 | 07:09 PM
  #32
TOM R's Avatar
Ive had the same plastic aluminum ebay rad for years
Old Feb 12, 2020 | 08:06 PM
  #33
Best4x4's Avatar
I'm gonna give the Ebay wonder a try looks like the darn cooler lines will work so we'll see!
Old Feb 13, 2020 | 06:44 AM
  #34
TOM R's Avatar
Im sure u can get some brass threaded adapters from the big box or fastenal, you just need to know the sizes, either a female to male to replace that factory fitting or
, got lowes or parts store and get a female female brass threaded coupler, looks like pipe thread , unless it will stop the lower line from fitting
Old Feb 13, 2020 | 07:23 AM
  #35
Best4x4's Avatar
I took the adapter from the radiator & couldn’t find anything locally. Ebay vendor has finally contacted me so working on a return. I’ll just run the plastic tank unit and call it a day. I also ordered new support bushings as they were all rotten/cracked.
Old Feb 13, 2020 | 09:41 AM
  #36
whiskeynipple0088's Avatar
best 4x4 - take a look at post #7 thats what the adapter should look like - got it from Atlantic british. But if you can - return it. Yours looks exactly like mine aluminum one did and that didnt last but 6 months before I noticed it was leaking.
I tried contacting the seller of mine and they would not respond - so I got taken.
Old Feb 13, 2020 | 12:54 PM
  #37
Best4x4's Avatar
I have those adapters from my OEM radiator. The aluminum one = can’t thread those into the radiator as their nipples are welded on. They do not unthread from the radiator so those adapters are 100% useless. I was shown a set of female/male adapters from an older RRC, but my buddy said good luck finding them today.
Old Feb 14, 2020 | 07:50 AM
  #38
Gotcha, I see it now. Didnt mean to add confusion.
Old Feb 14, 2020 | 08:00 AM
  #39
Best4x4's Avatar
Oh no problem, Ebay vendor is giving me the run a round so I doubt anything is gonna happen with that. Replacement plastic tank unit will be here Tuesday.
Old Feb 16, 2020 | 01:53 PM
  #40
Best4x4's Avatar
An FYI for anyone needing a replacement radiator the difference between the 159.00 generic plastic tank radiator & the Nissens 330.00 plastic tank radiator = the darn sticker that says Nissens. I have a Nissens in my XD and I looked it over from head to toe vs the QWP branded 159.00 generic unit and they are 100% identical. So personally I'd save some $$$ and just get the 159.00 unless the name means that much to you. I'd already have it installed, but I am waiting on some new radiator mount bushings.
ajnolin
Sep 9, 2018 12:36 PM
bmeier
Jan 13, 2015 09:16 PM
jamieb
Aug 1, 2014 11:21 AM
greg617ma
Dec 11, 2012 07:05 PM
thebloody
Apr 18, 2012 07:53 AM
