Not the Blower Motor, transistor?
Old Apr 11, 2013 | 06:38 PM
  #21
...huh?
Old Apr 14, 2013 | 12:08 AM
  #22
calebbo's Avatar
No clue, I must have been exhausted at night reading the forums or something haha.
By the way I realized when my AC/Heat doesn't blow my rear windows stop working. But when it kicks on the windows are functioning again. Weird Rover..
Old Mar 29, 2017 | 12:42 AM
  #23
notny41's Avatar
I'm reviving this thread.
How in the world does that climate control come out of the dash???
I got the trim cover off and took the 4 screws out behind that but can't figure out how it comes out. In my efforts to try to wriggle it out, I broke off two of the little tabs that help to hold it in place. (eeek!)
I'd love to take my blower switch apart and see if I could get it working better.
Thanks!
Attached Thumbnails Not the Blower Motor, transistor?-20170328_211639.jpg   Not the Blower Motor, transistor?-20170328_211612.jpg   Not the Blower Motor, transistor?-20170328_211533.jpg   Not the Blower Motor, transistor?-20170328_211545.jpg
Old Mar 29, 2017 | 07:46 AM
  #24
OverRover's Avatar
You still need to remove the center dash panel . Let the fun begin!
Here is a good look of what you will need to do (forget all the "spider" BS) > Discovery 1 spider/centre dash removal
Old Mar 29, 2017 | 08:26 AM
  #25
notny41's Avatar
Wow! Much thanks OverRover! That's a really good link!
Old Mar 29, 2017 | 01:35 PM
  #26
hrhoward's Avatar
Thanks!
I have taken the blower switch apart a couple of times. Watch out for the wee springs! Mine had gotten crispy hot at the elec. connector. Inside of the switch was a nasty greenish color. Cleaned it with some 00 steel wool. Works pretty good. Still have to jiggle it now and again. Bought a rear climate switch control out of a D2. Same blower switch. Going to swap them out when I get motivated.
Old Mar 29, 2017 | 09:46 PM
  #27
notny41's Avatar
Well I finally got my dash apart and the switch out (thought I was going to break something pulling that switch out).
Here is what it looked like right after I took the cover off:
After hitting it with a couple shots of MAF cleaner, the blue arrows (above) show the line of plastic that had melted and kind of mushroomed up. On the right hand side (right next to the rivet) some plastic looked like had been covering the contacts up. I ended up scraping that off with a jackknife.
I removed the plastic ridge from that channel with an exacto knife (hard to tell, but the picture below shows a much cleaner set of contacts).
Then I put it all back together and tested each of the contacts with a multimeter. All seemed good. Put the switch and dash back together and it works beautifully! The one thing I don't have still is fan on the lowest setting. I have a feeling my fan is kind of gummed up and that lowest setting just doesn't have enough juice to get it spinning. That's probably why there was so much heat built up to melt some of that plastic too. So I may be looking at my fan motor at some time.
Also when putting everything back, I somehow managed to disassemble my cup holder. I was able to get it back together but then it would not go in far enough to latch. It took me a really long time to figure out how to put it back together so it worked but I finally figured it out. Oh well, it gave me a good reason to clean all of the pieces before putting them back together - there was some serious gummy crap on some of those pieces too...
Thanks for all of the help on the switch and console pieces!
Attached Thumbnails Not the Blower Motor, transistor?-switch-parts-after-opened.jpg   Not the Blower Motor, transistor?-switch-melted-plastic.jpg   Not the Blower Motor, transistor?-switch-parts-all-cleaned-up.jpg   Not the Blower Motor, transistor?-cup-holder-parts.jpg
Old Mar 31, 2017 | 12:47 AM
  #28
notny41's Avatar
Pulled the blower motor out tonight. There were a few leaves stuck in the fins of the fan, but not just too bad. The motor seemed like it was a little sticky when I turned it. I found the access door to the inside of the motor and squirted some white lithium grease on the shaft where the bearing is.
Then I drilled a small hole big enough to get the straw of the white lithium grease thru so I could get some grease down into the other bearing/shaft too.
The drum seemed to move a little easier, but after putting the blower back on the car, I still don't have any fan on position 1 of my switch. I'm fine with that so long as 2, 3, and 4 work well.
Attached Thumbnails Not the Blower Motor, transistor?-20170330_195219.jpg   Not the Blower Motor, transistor?-20170330_195202.jpg
angrylobster
Jun 28, 2015 04:43 PM
03discoken
Mar 9, 2015 03:47 AM
james.martin1
Feb 21, 2015 05:58 PM
mycleo
Sep 7, 2013 08:24 PM
imnappraiser
Aug 27, 2009 12:16 PM
